Flow discharge between 2 open water bodies connected by a concrete sluice
The discussion focuses on calculating flow discharge between two open water bodies connected by a trapezoidal concrete sluice with gates. The discharge rate is approximately 50m^3/s, with an average velocity of 3-5 m/s. Key considerations include the impact of a vacuum suction divide and a vertical axis turbine on flow rate and head loss. Participants suggest using appropriate hydraulic design equations and refer to the HDS5 Hydraulic Design of Highway Culverts for guidance, noting potential errors in some nomographs. Calculating a system curve is recommended to determine the allowable head loss due to the turbine at the specified flow rate.
krissturm
Hello,
Looking for help with a physics problem.
I am dealing with a problem regarding the flow discharge between 2 open water bodies connected by a concrete sluice with gates. The issue is that the channel is not straight but rather a trapezoid (image of the cross-section below). The discharge from 1 of the gates is said to be ~50m^3/s and the average velocity is between 3-5 m/s.
I would like to know what kind of formulas should I be looking for when dealing with such a shape. In the middle of the dike, there is a vacuum suction divide that creates a vacuum so that the water can flow freely. Additionally, a vertical axis turbine will be installed there so how should I approach the losses that the turbine will add to the flow rate?
The length from 1 basin to the other is 65m. The openings are 3.2m x 3.2m and the water level on one side is approx. -80cm NAP and on the other side approx. -30cm NAP
Is this a professional engineering question?
Take a look at HDS5 Hydraulic Design of Highway Culverts. It's a free PDF, but be aware that at least one of the nomographs is seriously in error. Use the equations, those are correct.
Hint 1: It's under inlet control.
Hint 2: Calculate a system curve. That will tell you exactly how much head loss you can add with a turbine at your desired flow rate.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
