Physics Puzzle: Magnetic Field Generated by Approximation of a Flower
  • Thread starter Thread starter cpcolts
    Physics Puzzle
The discussion revolves around the magnetic field generated by an artist's approximation of a flower using straight lines and arcs. It questions whether a magnetic field exists at the center when a current flows along these lines. The initial conclusion is that no magnetic field is generated because flowers cannot be magnetized, which renders the subsequent questions about the effects of altering the number of petals or the dimensions of the flower moot. Participants suggest simplifying the problem by reducing the number of petals to better understand the magnetic field's behavior. Ultimately, the consensus is that the premise of generating a magnetic field from this configuration is flawed.
cpcolts
Here's an attachment.
A poor artist might approximate a flower as a series of straight lines and arcs such as that shown below. We could caracterize the flower by specifying the inner and outer radii, and the inner and outer angles (shown). If a current I flows around along the lines and arcs, a magnetic field may be generated at the center of the figure. For the figure as drawn, please answer each of the following questions.
Will there be a magnetic field at the center?
If there is a field, would increasing the number of "petals" make the field bigger? Smaller? No effect?
If there is a field, and with the other variables fixed, will increasing Router make the field bigger? Smaller? No effect?
If there is a field, and with the other variables fixed, would making outer bigger and inner smaller make the field bigger? Smaller? No effect?
Have you at least attempted to solve this?
Sounds like homework...
as a start consider reducing the number of petals...maybe to two opposite...or even just one...easier to figure out what happens...
The answer to the first question is 'no'; flowers can't be magnetized. That negates the remainder of the questions.
yea. I've tried figuring it out but had no luck so far
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
