Physics with calculus. Prior to Calculus
Understanding the basics of calculus is essential for successfully navigating a physics course that incorporates calculus concepts. While it is possible to grasp many physics principles without delving deeply into calculus calculations, a solid foundation in derivatives and integrals is necessary for deriving key physics equations. If the physics class heavily relies on calculus and the student struggles with the material, it may be wise to consider dropping the course. However, if the calculus is primarily presented in lectures and algebra can be used for problem-solving, the student might still manage to succeed with additional effort. Engaging with the professor for clarification and support is also recommended, especially if the majority of classmates are in a similar situation.
Kendal
This is my first year in college, and I am currently taking calculus 1, and physics w/ calculus.
My academic adviser told me that I would be okay taking the two together since I'd be learning the calculus as i went. This doesn't seem to be the case because for a lot of my problems we are already using derivatives and integrals. Is there a way I'll be able to use all of the Kinematic formulas (1D and 2D) without knowing much calculus? Should I continue trying to do work on physics with my little calculus knowledge or should I really invest my time in figuring out calculus first.
TL;DR: Can I get by in physics w/ calculus without knowing most calculus, or should I learn the basics of calc first and drop the physics class for now?
You certainly need to understand the basics of calculus. You can understand a lot of physics while skipping the details of the specific calculus calculations. Eventually you will have to understand how to calculate derivatives and integrals to be able to derive several physics equations. But you can understand most of them without necessarily deriving them.
so would it be smart to drop physics? or is it possible for me to still get at least a B in there?
If you are already supposed to be using integration and differentiation to solve problems, then it would probably be in your best interest to drop the class. However, if the calculus is just in the lecture and you can use algebra to solve the problems, you might be okay.
Likes CalcNerd, FactChecker and Student100
How many of the other students in your physics class are in the same situation as you?
Likes symbolipoint
maybe 2-3
Hmm that's not so good. I learned a lot (a lot!) of math in my physics classes, but we were all in the same boat so the profs had to take the time to teach us the math as we went along. If that isn't happening in your class you may be at a real disadvantage. On the other hand, if it's simple stuff you might be able to pick up what you need with a little extra effort and help.
Likes FactChecker
Have you talked to the professor / instructor about this?
Likes gmax137
