Physics : Work Energy Power Question
The discussion centers on a physics problem involving a bullet and a wooden block, where the bullet's initial speed is calculated based on conservation of energy principles. The user initially misapplied the conservation of kinetic energy, resulting in an incorrect speed of 19.5 m/s instead of the correct 116.5 m/s. The error was clarified as a misunderstanding of energy conservation during the collision, where momentum is conserved instead. Additionally, a separate question about the work done by a boy holding a weight is introduced, emphasizing the need to understand work in the context of force and displacement. The conversation highlights the importance of distinguishing between energy conservation and momentum conservation in collision scenarios.
Gunman
A bullet of mass 0.0035 kg is shot into a wooden block of mass 0.121 kg.
They rise to a final height of 0.547 m as shown. What was the initial speed (in m/s) of the bullet before it hit the block?
http://www.physics247.com/physics-homework-help/conservation_nrg_quiz1.php"
There is a picture there on how the setting looks like.
K.E of bullet = P.E of the total mass at its final height
1/2mv(square) = (m+M)gh
(1/2)(0.0035)v(square) = (0.0035 + 0.121)(9.81)(0.547)
v = 19.5m/s
The actual answer is 116.5m/s.
Where did I go wrong? :confused:
Ya. Thanks for any help provided. And since this is my first time posting forgive me if there are any mistakes in the way I posted the question. Thankx again. =)
Here's where you went wrong: Mechanical energy is not conserved during the collision (some of the bullet's kinetic energy becomes thermal and deformation energy). But another physical quantity is conserved during any collision--what is that?
After the collision, the mechanical energy of "bullet + block" is conserved.
Thanks man. =) I got it. So the momentum of the system is conserved. So by using that I can solve this. Hm..Thank you very much for clearing my misconception. :)
please help me answer this question..
A boy holds a 40-N weight at arm's length for 10 seconds. His arm is 1.5m above the ground.The work done by the force of the boy on the weight while he is holding it is?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
