Solving Pinned Jointed Frame Exterior Reactions
  • Thread starter Thread starter matthew_hanco
    Frames
The discussion focuses on calculating the exterior reactions for a pinned jointed frame, specifically at point A. The user initially calculated horizontal and vertical forces but struggled with accuracy, leading to discrepancies with their lecturer's results. Key calculations included summing moments and forces, with the lecturer confirming the correct resultant reaction force at point A as 22.20 kN acting at an angle of 26.77 degrees from the horizontal. The user was advised to ensure correct dimensions on their free-body diagram to resolve the discrepancies.
  • Understanding of static equilibrium principles in mechanics
  • Familiarity with free-body diagrams
  • Knowledge of calculating moments and forces
  • Proficiency in trigonometric functions for resolving forces
  • Review the principles of static equilibrium in structural analysis
  • Learn how to accurately create and interpret free-body diagrams
  • Study the application of trigonometric functions in force resolution
  • Explore common errors in calculating resultant forces and moments
Engineering students, structural analysts, and professionals involved in mechanics and structural design who seek to improve their skills in calculating forces and reactions in pinned jointed frames.
matthew_hanco
The problem is attached to this post, basically i need the exterior reactions and how to work them out.
i know i need to take moments I am just not sure how to work it out.
Basically what i worked out
is
i assumed horizontal members are equally to 1
sum of the horizontal = 0 5Kn- HA - HE=0
Sum of the vertical =0 10KN- VA =0
But that is where I am stuck i know the numbers should be roughly
HA=20
VA= 10
HE = 15
But i know it is more accurate than that I am not sure if i need to include sine or cosine in the solution
Thanx in advance
To add to it i have just tried
sum MA= 0
Therefore he x 2 - 5x1 - 10x2 =0
he =12.5
sum of horizontal 5+12.5 =17.5
therefore ha = -17.5
sum of the vertical
Va -10 x 1 =0
so Va = 10
Is that right?
Im desperate and really need someones help urgently.
matthew_hanco said:
sum MA= 0
he =12.5
Hi matthew,
Since you're taking moments around A and since the 5 kn and 10 kn forces produce opposite moments around A, one of your terms needs to be positive and one needs to be negative. You have a negative moment around A for BOTH of these forces.
Once you get the horizontal force from E you can sum forces and get the horizontal and vertical forces on A.
ok so the new calculated resultant forces would be
He= 15 ( (-10 x 2) - (+5x1) + He=0)
Ha= -20 (+15 + 5 - ha= 0 therefore Ha= -20)
Va= -10 (+10 -Va=0)
But now checking my lecturers answers he gives
14.82 for He
And a resultant force for a 22.2 acting 26.46 degrees from the horizontal
But with my results the resultant for a is 22.36 and 26.56 from the horizontal.
who is right, if he is how can i account for the discrepencies
Those answers are all pretty close, so I would guess the differences are in rounding error. Regardless, I can't check the math because the figure you provide has no dimensions on it.
All forces are in KN
I can see the forces. There are no linear dimensions on your picture.
matthew_hanco: The dimensions are already fully defined by the diagram given in post 1. The resultant reaction force at point A from your lecturer, 22.20 kN, is correct. However, the orientation angles given by both you and your lecturer are currently incorrect. The resultant reaction force at point A is 22.20 kN acting 26.77 deg from the horizontal. Keep trying. Your discrepancies are not due to round-off error. First, figure out the correct dimensions of your structure, and label them on your free-body diagram. You currently appear to be using wrong dimensions.
Got it, the length should be root 3 instead of 1.
so it should be
(-10 x (root3x2) - +5x1)/2=Ha
Excellent, matthew_hanco.
