cshum00
- 215
A massless stick is pinned at point A. And it has a concentrated ball mass of 1kg attached to it at point B.
Given the initial values:
Initial angular position θ=45◦
Initial angular velocity ω=0
Initial angular acceleration α=0
Show that because of the setup of the problem, the concentrated mass B follows a circular path of:
x = \sqrt{2}cos\thetay = \sqrt{2}sin\theta
The tangential acceleration is induced by the gravitational force on the mass:
ma_t = mgcos\theta
The stick reacts to the compressive force induced by the ball mass, which is also the centripetal acceleration:
ma_c = AB = mgsin\theta
Find the forces acting at point B:
\sum F_x= ma_xAB_x = ma_xABcos\theta = ma_xmgsin\theta cos\theta = ma_xa_x = gsin\theta cos\theta
\sum F_y= ma_yAB_y - mg = -ma_y-ABsin\theta + mg = ma_ym(g - gsin^2\theta) = ma_ya_y = g(1 - sin^2\theta)a_y = gcos^2\theta
To find the x and y positions simply double integrate the respective accelerations ax and ay with respect to time.
x = \int \int a_x = \int \int gsin\theta cos\theta dt^2y = \int \int a_y = \int \int gcos^2\theta dt^2
However, the problem is that θ is a function of time or θ(t). In addition, although there is a constant vertical gravitational acceleration, the angular acceleration is not constant. Therefore, the equation for constant angular acceleration is not applicable:
\theta = \frac{1}{r}(\theta _0 + \omega _0 t + \frac{1}{2}\alpha _0 t^2)
So, in order to find θ, i have to use the tangential acceleration relation with the angular acceleration:
r\alpha = a_t\alpha = \frac{a_t}{r}r\theta = \int \int \frac{a_t}{r}dt^2
However, because the tangential acceleration is known in terms of θ, it sets me back to my original problem that i am trying to integrate θ with respect to time:
\theta = \frac{1}{r^2}\int \int gcos\theta dt^2
