Pion Nucleon Scattering and Group Theory in Quantum Field Theory
The discussion centers on Pion Nucleon scattering as described in Ryder's book on Quantum Field Theory, specifically focusing on the interaction term L_{int}=ig \bar{\psi} \gamma_5 \tau_a \psi \phi^a. The nucleon field, represented by \psi, is in the fundamental representation of SU(2), while the pions, denoted by \phi, correspond to Isospin multiplets with I-spin 1. The conversation highlights the relationship between the number of generators of the Pauli matrices and the states of nucleons and pions, emphasizing the need for a consistent treatment of these fields within the same representation framework.
  • Understanding of Quantum Field Theory concepts, particularly Pion Nucleon scattering.
  • Familiarity with group theory, specifically SU(2) representations and Pauli matrices.
  • Knowledge of Isospin multiplets and their physical implications in particle physics.
  • Basic understanding of interaction terms in quantum field theories.
  • Study the representation theory of SU(2) in detail.
  • Explore the role of Isospin in particle physics and its mathematical formulation.
  • Investigate the implications of interaction terms in Quantum Field Theory.
  • Read additional literature on Pion Nucleon scattering for deeper insights.
This discussion is beneficial for physicists, particularly those specializing in Quantum Field Theory, particle physics researchers, and students seeking to understand the intricacies of Pion Nucleon interactions and group theory applications.
Physiana
Pion Nucleon Scattering and a bit about group theory/ representations
Hello everybody,
I am going through Ryder's book about Quantum Field Theory right now. In the chapter about Pion Nucleon scattering he writes the interaction term like
[tex]L_{int}=ig \bar{\psi} \gamma_5 \tau_a \psi \phi^a[/tex]
where the [tex]\tau_a[/tex] are the Pauli matrices. I wonder now; [tex]\psi[/tex] is the nucleon field, [tex]\phi[/tex] the pions
my script of the lecture says that the nucleon is in fundamental representation of SU(2). So we have nucleon dublet corresponding to dimension of the Pauli matrices?
What representation does he use for the Pions? And why does the number [tex]\pi^-,\pi^+,\pi^0[/tex] correspond to the number of generators and the dimension of the [tex]\tau[/tex] to the number of nucleon States?
I do not exactly understand why I treat the dublet of proton and neutron so differently from the pion fields. Both are Isospin multiplets so I should actually describe them in the same "space"... e.g. regarding the nucleons also as a linear combination of the pauli matrices like we did with the pions, but then actually setting the coefficient of [tex]\tau_1[/tex] to zero [tex]\psi_1 = 0[/tex], because we do not have negative nucleon charge... I always thought the number of generators would correspond to the number of multiplets?
Thank you for your help :)
Is there really no one who has an idea?
The pion have Ispin 1.
The index a has the values 1,2,3, with 3 being like the z component.
Linear combos of 1 and 2 are + and -
The nucleon charge is [tex]q=(1+\tau_3)/2[/tex]
In vector notation it reads [tex]{\vec \tau}\cdot{\vec \phi}[/tex].
That is just like s.L in atomic physics, with L=1.
An older book on particle physics may have more detail than Ryder.
  • · Replies 75 ·
11K
  • · Replies 0 ·
  • · Replies 24 ·
