Piping commands with redirection
  • Thread starter Thread starter opt!kal
    Piping
The discussion centers on a programming assignment involving the implementation of UNIX command piping and redirection. The user encounters segmentation faults when trying to execute commands without a redirection symbol, indicating issues with how the redirect option is implemented. They have made progress by switching from `gets` to `fgets`, allowing for multiple piped commands but still face errors if the last command does not end with a redirection operator. The user seeks help to resolve these issues and ensure that commands can be executed correctly regardless of the presence of a redirection symbol. The thread highlights the complexities of handling command input and output in a UNIX-like environment.
opt!kal
Hi there,
So I am working on this assignment where the user is supposed to input a variety of UNIX commands and they must behave as if one typed it into the terminal. My current problem lies with when a user tries to redirect the inputted commands to some file. Currently it only works when a user has the redirect symbol, like:
ls -l | sort -n > temp.txt
However if I try to input:
ls -l | sort -n
I just segfault. I know the problem most likely lies in how I wrote the redirect option, but I can't seem to figure out how to make it so that the two above commands work.
Code:
#include <errno.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <unistd.h>
#include <sys/types.h>
#include <fcntl.h>
/*get args function*/
#define MAXARGS 256
char ** getargs(char * cmd) {
	// assumes that cmd ends with NULL
	char** argsarray;
	int nargs = 0;
	int nlen = strlen(cmd);
	int i = 0;
	argsarray = (char**) malloc(sizeof(char*) * MAXARGS);
	argsarray[0] = strtok(cmd," ");
	i = 0;
	while (argsarray[i] != NULL){
		i++;
		argsarray[i] = strtok(NULL," ");
	return argsarray;
}int main(void){
  pid_t childpid;
  int fd[256][2];
  char cmd[256];
  char * sepCmd[256];
  char * pch;
  char * srch;
  printf("Please enter a command sequence: \n");
  gets(cmd);
  //scanf("%s", cmd);
  printf("You have entered: %s \n", cmd);
  printf("Attempting to split up command: \n");
  pch = strtok (cmd, "|");
  srch = strchr(cmd, '>');
  *srch++ = '\0'
  while (*srch == ' ') ++srch;
  int count = 0;
    while (pch != NULL && count < 256) {
      printf("%s\n", pch);
      sepCmd[count] = pch;
      printf("The value in this array value is: %s\n", sepCmd[count]);
      pch = strtok (NULL, "|");
      count++;
  char ** argue;
  int k;
  /* Block that deals with the first command given by the user */
  k = 0;
  pipe(fd[k]);
  if(!fork()) {
	  	dup2(fd[k][1], STDOUT_FILENO);
		close(fd[k][0]);
		argue = getargs(sepCmd[k]);
		execvp(argue[0], argue);
		perror(argue[0]);
		exit(0);
  /*Loop that will control all other comands except the last*/
  for(k = 1; k <= count - 2; k++) {
	  close(fd[k-1][1]);
	  pipe(fd[k]);
	  if(!fork()) {
		  close(fd[k][0]);
		  dup2(fd[k-1][0], STDIN_FILENO);
		  perror(argue[0]);
		  exit(0);
  /*Block that will take care of the last command in the sequence*/
  k = count - 1;
  close(fd[k-1][1]);
  if(!fork()) {
          if (srch) dup2(open(srch, O_RDWR|O_CREAT), STDOUT_FILENO);
	  perror(argue[0]);
	  exit(0);
  while(waitpid(-1, NULL, 0) != -1);
Any help is greatly appreciated
So a little update,
I changed gets to fgets and it seems like it will take any amount of comannds piped together, but only if it ends with a redirection operator or else I get errors like:
<COMMAND>: invalid option -- '
where COMMAND is the last command in the sequence
Thread 'PLL - How to find all the gains of a PI corrector and fix Ki ? MATLAB'
Hello everyone, it's not really for my homework (because I'm not at school anymore) but I'm new and I don't know how to start a new forum. I've never done automatic before and I need help. I have a 2nd ordre PLL on MATLAB, with an NCO and a PI corrector; the PLL works via the Mid/End algorithm (that's part is ok). I need to find the link between the theoretical formulas and their values in the code to find the value of the gain Ki, and possibly that of Kp if it's not correct. Unfortunately...
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
