Pistons and pressure question help
  • Thread starter Thread starter lollol
    Pressure
The discussion centers on calculating the average pressure exerted on two equal pistons with a given force. The formula for pressure, P = F/A, is applied, and participants debate whether to combine the areas of the pistons. Clarification is sought on the meaning of "average," with some concluding that the average pressure remains the same regardless of whether areas are combined. It is emphasized that the force remains constant, and thus the average pressure calculation does not change. Overall, the confusion lies in interpreting the average pressure in relation to the individual pressures of each piston.
lollol
area of a piston is 0.02
what is the AVERAGE pressure exerted on 2 equal pistons if the force is 25 N
P = F/A
do you just combine the areas.. and divide the combined area by F
i just did... pressure = F/Area of 1 piston
and since it said average... they both give the same pressure.. add them up.. divide by two, and end up with the same pressure. Is this wrong?
I didn't combine the areas
can you write out the entire, complete question?
The force exerted on 2 pistons was 10 N.. let's say
Area of each piston is 2m
What was the average pressure on the pistons? The word average confused the heck out of me...
so I found the pressure on each... added them.. divided by 2... and got the same pressure
Was I supposed to add the two areas?
think about it. what has changed?
if you were to divide pressure by half then you must also divide F/a by half as well otherwise the equation won't work. if you do that then nothing has changed and your getting no where.
and just to give you an even bigger hint: force isn't changing either.
hope this helps
