Pivoting Stick (Rotational Dynamics)
The discussion revolves around calculating the angular speed of a pivoted stick as it passes through the vertical. The stick has a mass of 7.9 kg and a length of 1 m, pivoted 0.15 m from one end. The moment of inertia was calculated using the Parallel Axis Theorem, resulting in a total of 1.626. Potential energy at the highest point was determined to be 27.13 J, leading to an angular speed of approximately 5.776 rad/s. Clarifications were made regarding the notation used in calculations, ensuring accuracy in the problem-solving process.
santi_h87
I misunderstood the problem, and the answer is the correct one! sorry, and someone can close this post if necessary
A stick of uniform density with mass M = 7.9 kg and length L = 1 m is pivoted about an axle which is perpendicular to its length and located 0.15 m from one end. Ignore any friction between the stick and the axle.
The stick is held horizontal and then released. What is its angular speed as it passes through the vertical.
[PLAIN]https://wug-s.physics.uiuc.edu/cgi/courses/shell/common/showme.pl?cc/DuPage/phys2111/summer/homework/Ch-10-Rotation/pivoting_stick/5.gif
1) First I calculated the moment of inertia about the axle using the Parallel Axis Thm:
Itotal = Icm + Md2
d = 0.50 - 0.15 => d = 0.35
Itotal = (1/12)ML2 + Md2 => Itotal = 1.626
2) I calculated the potential energy when the center of mass is at its highest point:
U=Mgh => U=Mgd => U=27.13 J
2) When this potential energy is 0, it's kinetic energy is maximum, so:
(1/2)Itotalw2=U => w=sqrt(2U/Itotal) => w=5.776 rad/seg
I will appreciate any help!
Why is the potential energy Mgd? Where is your zero of potential energy?
Itotal = Icm + Md2
Hi santi_h87,
Your answers are correct. But d symbol is not the same on your diagram and the calculation d.
