Maxo
- 160
- 1
If a plane flies from point W due east to point E and then from E due west to W, does it take equally long? Why doesn't the rotation of the Earth makes it shorter going E to W?
Maxo said:If a plane...
Maxo said:Thanks for the explanations, very interesting.
Here's another (kind of) related question. If the mass of Earth would change, would that affect the banking of airplanes as they turn? If so, how? I don't see why it should. The banking of airplanes as they turn are dependant on the lift force of the engines, which is not connected to the mass of the Earth. Or?
When you fly east, you are moving in the same direction as the Earth's rotation. This means that you are essentially chasing the sun and your day will be longer. On the other hand, when you fly west, you are moving against the Earth's rotation and your day will be shorter.
This is because the Earth is divided into 24 time zones, with each zone being one hour apart. As you travel east or west across these time zones, you are essentially changing your location on Earth and therefore, experiencing a change in time.
Pilots and airlines use a standardized system called Coordinated Universal Time (UTC) to account for time differences. This system is based on the Earth's rotation and is used as a reference for all time zones. Pilots also use navigation equipment and flight plans that take into account the time differences between their departure and destination airports.
No, the time difference is not the same for all flights. The time difference depends on the distance you are traveling and the number of time zones you are crossing. For example, flying from New York to London (east-west) will have a time difference of approximately 5 hours, while flying from New York to Los Angeles (west-east) will have a time difference of only 3 hours.
Yes, flying east-west can affect our body's internal clock. This is because our bodies have a natural 24-hour cycle, known as circadian rhythm, which is synchronized with the rising and setting of the sun. When we travel across time zones, our circadian rhythm can be disrupted, leading to jet lag and other symptoms such as fatigue, insomnia, and disorientation.
