What is the relationship between force and distance in planetary motion?
The discussion centers on the relationship between force and distance in planetary motion, specifically how the horizontal component of gravitational force (Fx) is derived from the complete force (|F|) using similar triangles. The equation Fx = -|F|x/r^3 is established, where the negative sign indicates the attractive nature of gravitational force. Participants clarify that the negative sign is necessary to ensure the force direction aligns with the physical behavior of the system, regardless of the sign of x. This mathematical representation is essential for accurately describing gravitational interactions in planetary motion.
  • Understanding of gravitational force and its components
  • Familiarity with similar triangles and their properties
  • Basic knowledge of calculus, specifically derivatives and rates of change
  • Concept of gravitational attraction in classical mechanics
  • Study Newton's Law of Universal Gravitation
  • Learn about the derivation of gravitational force components in polar coordinates
  • Explore the application of Hooke's Law in gravitational contexts
  • Investigate the mathematical modeling of planetary motion using differential equations
Students of physics, educators teaching classical mechanics, and anyone interested in the mathematical foundations of gravitational interactions in planetary motion.
rudransh verma
https://www.feynmanlectures.caltech.edu/I_09.html
9-7
"From this figure we see that the horizontal component of the force is related to the complete force in the same manner as the horizontal distance x is to the complete hypotenuse r, because the two triangles are similar. Also, if x is positive, Fx is negative. That is, Fx/|F|=−x/r, or Fx= −|F|x/r= −GMmx/r3. Now we use the dynamical law to find that this force component is equal to the mass of the planet times the rate of change of its velocity in the x-direction".
I don't understand when the ratio of corresponding magnitudes are equal for similar triangles why is it taking -ve sign with x?
Look at the drawing. The force Fx points to the left (is -ve) whilst x is +ve. Now imagine the planet being on the other side of the y-axis at the mirror-image point. In this case Fx points to the right (is +ve) whilst x is -ve because it on the negative side. The -ve sign in front of x/r makes sure that the gravitational force is attractive and points in the right direction regardless of whether x is +ve or -ve.
But mathematically speaking we cannot put -ve sign. We are just using the property of similar triangles. One ratio is not equal to -ve of another ratio.
You asked and I replied. Similar triangles can be used to establish relations between magnitudes without reference to signs. This doesn't mean that we are prohibited to put a -ve sign where it belongs. Here, we are describing a physical situation using the language mathematics. Therefore, we are perfectly entitled to put -ve signs where they are needed in order to match the mathematical description to the observed behavior of the system.
Okay! Thanks.
Like hookes law it is also a law.
  • · Replies 86 ·
  • · Replies 29 ·
  • · Replies 20 ·
