Plastic Engine Block Cooled with liquid metal
Research into plastic engine blocks and cannon barrels is limited, but there is interest in using high-temperature plastics in extreme environments. The discussion highlights the potential of graphite powder and epoxy composites combined with liquid sodium as a coolant for engine blocks, emphasizing weight reduction and ease of production. Concerns are raised about the feasibility of plastic cannon barrels, particularly regarding heat resistance and structural integrity. Suggestions include using concrete jackets and metallic liners to enhance performance, although questions remain about the advantages over traditional steel barrels. Overall, the conversation explores innovative materials for high-stress applications while acknowledging significant challenges.
Mustafa Umut
Is there any research done on plastic engine blocks or cannon barrels ?
I interested in using plastics at high heat high pressure environments after learning some researchers cools 1600 degree plate to 80 degrees with potassium or sodium or exotic metallic liquids.
I think it might be possible to produce a block out of graphite powder and epoxy composite ,
use liquid sodium as a coolant and use of metallic liners.
Other high wear parts could be made from metal but think the weight reduction of the engine and the easy of production.
I need your ideas ,
Best ,
Mustafa Umut Sarac
Istanbul
By the way , if you interested to cool something with liquid metals , look to nuclear power stations or ibm news.
Best ,
Mustafa Umut Sarac
Istanbul
I can think of at least a couple other problems with plastic cannon barrels, beyond heat.
If you jacket the barrel with concrete and if you use a liner , you reach somewhere possible.
Best ,
Mustafa Umut Sarac
Istanbul
Best ,
Mustafa Umut Sarac
Istanbul
With all that extra stuff, what would be the advantages over the traditional steel barrel?
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
