Please check if i am right - definite inegral
  • Thread starter Thread starter DemiMike
DemiMike
The question:
Use the definiton of the definite inegral (with right hand rule) to evaluate the following integral. Show work please
Can NOT use shortcut method.. must be the long process
Function:
S (3x^2 - 5x - 6) dx
-4
Work:
∫[-4,1] (3x^2 - 5x - 6) dx =
lim[n-->∞] 5/n ∑[i=1 to n] {3(-4 + 5/n)² - 5(-4 + 5/n) - 6} =
lim[n-->∞] 5*∑[i=1 to n] (48/n - 120i/n² + 75i²/n³ + 20/n -25i/n² - 6/n) =
lim[n-->∞] 5*∑[i=1 to n] (62/n - 145i/n² + 75i²/n³) =
lim[n-->∞] 5[62n/n - 145n(n+1)/(2n²) + 75n(n+1)(2n+1)/(6n³)] =
5(62 - 145/2 + 25) = 72.5
∑[i=1 to n] 1 = n
∑[i=1 to n] i = n(n+1)/2
∑[i=1 to n] i² = n(n+1)(2n+1)/6
Please check if this is correct and let me know
That looks ok to me. Even if you can't use the 'shortcut method' to solve the problem, you can always use the shortcut method to check your work.
it looks ok to me to =P, but i wanted to make sure if it's completely right
-thanks =)
which shortcut formula would i have to use
-thanks =)
I was assuming the 'shortcut' method was finding the antiderivative and evaluating it between the two limits. If you haven't learned that yet, then never mind.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
