Please explain to me why this simple problem is so
  • Thread starter chambershex
  • Tags
    Explain
In summary, the conversation discusses the concept of expanding an equation using the order of operations and the distributive law. The question is raised as to why this is a valid mathematical concept. The conversation also explores the idea of fundamental rules in mathematics and the consequences of making a mistake in these rules. A geometric explanation is provided to illustrate the difference between (x+y)^2 and x^2 + y^2.
  • #36
Yes of course its enough to prove their different, but it doesn't explain WHY in the same sense that the original question I asked was described (with reference to the distributive law etc.). Also I wonder if its possible to represent the question geometrically much like the first one? But I don't want anyone to go to any more trouble, the main point of this thread was to just clarify some things for me conceptually, which it has done, and I thank everyone for their time.
Mathematics news on Phys.org
  • #37
chambershex said:
Also I wonder if its possible to represent the question geometrically much like the first one? But I don't want anyone to go to any more trouble...
It's no trouble at all. Use Dickfore's drawing in post 17. Change x^2 to a and y^2 to b. Then the side of the entire square is sqrt(a)+sqrt(b).
Now the square of area a+b must be smaller than the entire square from the picture because the picture has those two extra rectangles. Smaller square means smaller side length, so sqrt(a+b)<=sqrt(a)+sqrt(b).
The reasoning is almost exactly the same.
  • #38
We don't need to keep proving everything from scratch every single time. We build on what we know and use those facts to prove further things.
  • #39
I just want to state on the record that this thread is bad and the OP should feel bad for starting it. In order to prove that something is not true, it is sufficient to find one particular counter-example. This was done in the first reply. Everything after this is nonsense.
  • #40
Are you a Futurama fan by any chance?
"Your music is bad, and you should feel bad!"- Dr. Zoidberg
  • #41
chambershex said:
Thanks for the response, but that's exactly the type of answer I didn't want (sorry if I wasn't clear). What you said shows both sides aren't equal but it doesn't tell me anything about WHY they aren't equal.
What do you mean why? In math we're interested in establishing true and false statements. A counter-example that disproves (x + y)^2 = x^2 + y^2 for some x and y shows that this statement is false. It ends there.
  • #42
You guys are great teachers. How inspirational!
  • #43
Haha I should feel bad for starting it? What is this a prestigious science journal? You should should feel bad for showing such pretentiousness. No one had to respond to this thread, but they chose to (including yourself). I already said before I got everything I wanted out this threa, so as far as I'm concerned it can be closed.
  • #44
Yes, you managed to troll us.
  • #45
Honestly, the OP confounds me. The two sides appear different -- there should be no surprise to find out they actually are different.
Incidentally, the original inequality is not an identity -- it fails when x is 0 or when y is 0.
Inequalities, incidentally, cannot be proven by manipulating equalities. One must invoke something that is intrinsically non-algebraic1, such as the inequality [itex]0 \neq 1[/itex] of ordinary arithmetic.
1: I mean "algebraic" in a specific technical sense -- e.g. referring to universal algebra, or to essentially algebraic theories.
  • #46
Mentallic said:
Well why don't you try it and find out the expansion :wink:
Well I had a go!
I can see the expansion pretty easily from the diagram although the diagram is not very good it does help visualise it.
You can see the 3x^2y 'slabs' that go on 3 sides of x^2 and the 3 y^2x 'columns which go on 3 vertices
  • #47
alice22 said:
Well I had a go!
Could you please draw a diagram like this for the expansion of [itex](x + y)^{4}[/itex]. Thanks. Appreciate it.
  • #48
Does the 'dick' in 'dickfore' happen to be a self-description by any chance? And btw finding a question extremely easy does not mean I boast the same intellect as you. So please, calling something 'trolling' because you simply find it trivial is really the height of arrogance.
EDIT: I am also aware of the irony that I am now actually trolling so don't bother to point that out.
  • #49
That sounds very interesting, and no doubt very complicated ;)
  • #50
chambershex, how come [itex]x + y \ne x \, y[/itex]? I know that, for example, [itex] 2 + 3 = 5[/itex] and [itex]2 \cdot 3 = 6[/itex] and [itex]5 \ne 6[/itex], but what's the reason behind this?
  • #51
alice22 said:
Unfortunately I cannot find a 4D drawing package!
Your previous diagram was not three dimensional either.
  • #52
Why are you being so insulting? You and H must be on a mission to demoralize and deter people from using PF. Sure, the OP doesn't think like us or know as much, but who here has explained WHY?!? I suspect the reason that no one has (explained why) is that you don't know. The first response was close... Something is not true unless it is ALWAYS true.
As for your question, they are different operations, and have different outputs.
  • #53
No it was a 2 dimensional representation of the vertices of a 3D shape to be precise, or at least my rather poor attempt at it.
There is a video on the web claiming to draw a representation of a 4D cube but I think I will be banned if I post a link to it so I won't, as I expect it may break forum rules, or something like that!
  • #54
But, for example, when [itex]x = y = 2[/itex] or [itex]x = y = 0[/itex] I get the same answer.
  • #55
I know your being nasty here, but I can answer that. The operation + is fundamental and cannot be broken down into anything more simple - what it means is self-evident. The operation x is derived from +, being defined as Y lots of X. Or alternatively X + X + X..., Y times. However, I'm sure someone could provide a better formal description.
  • #56
Oooh! Sounds too complicated ;) What does operation mean?
  • #57
Thank-you. I now understand why the first question I posed is true, however I'm still yet to really see a good, fundamental explanation of why the second question is true (the one referring to the roots).
The overarching reason I am asking these questions is because I have always had a problem with completing algebraic/arithmetical questions using explanations which are just accepted as truth. I am content enough once an explanation can get down to the level of the axiom, because I can accept certain fundamental, propositions are self-evident. "I suspect the reason that no one has (explained why) is that you don't know" - I think this statement is actually not far from the truth; on philosophical grounds much of the foundations of mathematics is problematic.
  • #58
No, 4 is not the same as 0. Surprised you didn't know that.
/trollfeeding
  • #59
Let us say that the second statement you were asking about was correct, i.e.
[tex]
\sqrt{a + b} = \sqrt{a} + \sqrt{b}
[/tex]
was correct. Then, take [itex]a = x^{2}[/itex] and [itex]b = y^{2}[/itex] for [itex]x, y > 0[/itex]. Our 'equality' becomes:
[tex]
\sqrt{x^{2} + y^{2}} = x + y
[/tex]
Then, square the above 'equality':
[tex]
x^{2} + y^{2} = (x + y)^{2}
[/tex]
But, you this is in contradiction with your first statement. Therefore, if you accept that the last equality does not hold, then neither can the second one.
  • General Math
  • General Math
