Understanding the Equation for Velocity Field in Cylindrical Coordinates
The discussion centers on the calculation of the velocity field in cylindrical coordinates using the equation $$\bar{v}=\nabla \times \psi \hat{k}$$, where $$\psi$$ is a function of $$r$$ and $$z$$ but not $$\theta$$. The correct expression for the velocity field is $$\bar{v}=(\frac{-1}{r} \frac{\partial \psi}{\partial z}, 0, \frac{1}{r}\frac{\partial \psi}{\partial r})$$. Participants noted the importance of dimensional correctness and clarified that the equation relies on the axisymmetric nature of the problem, leading to the cancellation of certain derivatives. The discussion also highlighted the alternative formulation $$\bar{v}=\nabla \phi \times (*)$$ for better clarity.
  • Understanding of cylindrical coordinates and their applications in fluid mechanics
  • Familiarity with vector calculus, specifically curl and gradient operations
  • Knowledge of axisymmetric flow and its implications on derivatives
  • Basic principles of fluid mechanics, particularly related to velocity fields
  • Study the derivation of the curl in cylindrical coordinates
  • Learn about axisymmetric flow and its mathematical implications
  • Explore the relationship between current functions and velocity fields in fluid dynamics
  • Investigate dimensional analysis in fluid mechanics to ensure correctness in equations
Students and professionals in fluid mechanics, particularly those dealing with cylindrical coordinate systems and velocity field calculations.
Remixex
The problem is much bigger, i know how a rotor or curl is calculated in cylindrical coordinates, but I'm just asking to see what would be the "determinant" rule for this specific curl.
$$\psi$$ is in cylindrical coordinates (r,theta,z) and depends only on r and z, not theta meaning $$\psi(r,z)$$
I'm asked to write the velocity field in therms of the current function psi, and i know i have to do it with said equation above, i believe the determinant rule used (given this is a demonstration and i already know the answer) was
(i tried doing a matrix and i couldn't, but the bottom line of the determinant looks like it was 0 & psi & 0, so the result should yield) $$\bar{v}=(\frac{-1}{r} \frac{\partial \psi}{\partial z}, 0, \frac{1}{r}\frac{\partial \psi}{\partial r})$$
I think i solved it by myself, but if this is wrong I'd like some inputs.
All the theta derivatives are zero because psi doesn't depend on theta (1)
The middle therm is zero because the flux is axisymmetric, therefore the derivatives on each side are the same, cancelling each other (2)
Did you mean ##\nabla \times (\psi \hat\theta)## instead of ##\nabla \times (\psi \hat k)##?
You can tell your answer isn't dimensionally correct. If ##r## and ##z## have units of length, the derivative should only only introduce one power of length in the denominator. Your result has two.
I'm answering this absolutely late but i solved this doubt the next day asking my tutor
The equation, even though given as an "absolute" in the textbook (it implies it can be used everywhere) it depends on the flux, it is
$$\bar{v}=\nabla \times \phi(*)$$ where the asterisk (*) is the coordinate the current function does not posses, in this case phi is a function of r and z, therefore the asterisk must be a theta.
In any case i find much more comfortable using
I believe it's a similar equation, with another syntax, that relates velocity field with current function
Thanks for your answer anyways
PS=I'm struggling a lot in this fluid mechanics c(o)urse
