Please help prove this fact about a ball falling....
The discussion centers on proving that the time taken for a ball thrown vertically to reach its maximum height is equal to the time it takes to fall back to the ground. Participants agree on the logical premise but seek a mathematical proof without using calculus. Basic kinematic equations for motion under constant acceleration are referenced, specifically focusing on gravitational acceleration. The proof involves calculating the time to reach maximum height and the time to fall back down, both yielding the same result when using the kinematic equations. Ultimately, the conclusion is that the time taken to ascend equals the time taken to descend, confirming the original assertion.
oofllama
Why is the time it takes for a vertically thrown ball to reach max height the same as the time it takes for the same ball to fall from max height to ground level?
I agree with this logically but I can’t prove it mathematically...
Can you please show me the mathematical proof for this fact without using calculus skills?
Thank you! ^^
Thank you! ^^
What formulae have you been taught for motion under constant acceleration?
Hmmm ... tough without using calculus. The usual proof is to start with Newton’s 2nd law of motion: F = ma and integrate twice to get
x = x0 + v0 t + 1/2 a t^2
Plug in the numbers and voila’. However without calculus I’m not sure what to say
I guess one thing to say is that the laws of physics don’t change under time reversal, but that’s a statement, not a proof.
Likes oofllama
What is the time dependence of the velocity v?
We have to use two equations that are offered to us by basic kinematic theory for the case of motion with constant acceleration a.
##v=v_0+at## (1)
##s=v_0t+\frac{1}{2}at^2## (2)
The strict proof of these two equations requires calculus but can be done also with graphical methods, by the graph of acceleration versus time (for the proof of (1)) and by the graph of velocity versus time (for the proof of(2)).
So let's see how we apply these two equations in this problem. The constant acceleration is the gravitational acceleration g (will be changing sign depending how we apply the equations).
When we throw the ball up with initial velocity ##v_0## its velocity ##v## at time ##t## is given by equation (1), where ##a=-g## because now the gravitation acceleration opposes the initial velocity ##v_0##
So it will be ##v=v_0-gt## (3). If we put ##v=0## that means that the ball is at its highest point so the time ##t_u## to reach there can be found if we solve (3) for the time so it will be ##0=v_0-gt_u \Rightarrow t_u=\frac{v_0}{g}##
Equation (2) will become (because in this case acceleration is ##a=-g##) ##s=v_0t-\frac{1}{2}gt^2## . if in this last equation we plug ##t=t_u=\frac{v_0}{g}## and after we do some algebra we ll find that the distance (height) ##s_u## that is traveled for the time duration of ##t_u## is equal to ##s_u=\frac{v_0^2}{2g}##.
So, the time to go up is ##t_u=\frac{v_0}{g}## and the distance (maximum height) that it travels is ##s_u=\frac{v_0^2}{2g}##.
Now we take the case where the ball starts falling from its highest point. We apply again equation (1) but this time acceleration is taken as positive ##a=g##, and also the initial velocity ##v_0=0##. So if we apply equation (1) for the velocity ##v_d## that it will have at the lowest point, and suppose that this will take time ##t_d## we ll have from (1)
##v_d=0+gt_d## (4)
Now we know that the distance that it will travel going down ##s_d## is the same as ##s_u## so it will be ##s_d=s_u=\frac{v_0^2}{2g}## (the ##v_0## here is the ##v_0## from the process of going up).
The time it takes to go down ##t_d## can be found if we apply equation (2) . It will be
##s_d=0+\frac{1}{2}gt_d^2 \Rightarrow t_d=\sqrt\frac{2s_d}{g}##. If we plug ##s_d=\frac{v_0^2}{2g}## and after some algebra we ll find that the time ##t_d=\frac{v_0}{g}##. So it will be ##t_d=t_u## which we wanted to proof.
And also the velocity ##v_d## after it falls at the lowest point will be from (4) ##v_d=gt_d=g\frac{v_0}{g}=v_0##
Likes oofllama
