Please prove or disapprove this equality
  • Thread starter Thread starter bayes
The equality in question, sum_(n in Z)e^(2 pi i n s) = 2 delta(s), is debated, with some arguing it is false. The right-hand side should instead be represented as sum_{n in Z} delta(s-n), based on Fourier series principles. The discussion highlights that the sum does not converge, as the limit of e^(2 pi i n s) does not approach zero as n approaches infinity. Participants emphasize the need to analyze the Fourier series expansion of the function with a period of one. The conclusion suggests that the original equality does not hold true.
bayes
Please help me prove or disapprove the following equality:
sum_(n in Z)e^(2 pi i n s) = 2 delta (s)
Z is the set of integers and s any variable and delta is the usual delta function that is 0 when s is different from 0 and infinite if s is 0.
Thanks
Mathematics news on Phys.org
I think it's false.
Based on Fourier series I think the RHS of that equality should, [instead of 2 delta(s)], read:
\sum_{n\,\, \mbox{\rm in Z}} \delta(s-n)
Hint : Consider the Fourier series expansion of the above (period=1) function of s.
By what you wrote above did you mean
\sum^{\infty}_{n=-\infty} e^{2 \pi i n s}
This sum doesn't converge because lim_{n\rightarrow\infty}e^{2 \pi i n s}\neq0
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
