How to plot the linear system solutions with multiple solutions?
The discussion focuses on solving a linear system of equations involving parameters a and b, using Cramer's rule and Kronecker-Capelli's theorem. For b ≠ 0, a ≠ 1, and a ≠ -2, the system has a unique solution represented as a point in 3D space. When a = 1, the system yields infinitely many solutions if b = 1, or is inconsistent otherwise, leading to a line of solutions. In the case where a = b = -2, there are also infinitely many solutions, again forming a line. The discussion emphasizes the importance of plotting these solutions to visualize their intersections.
gruba
Solve the linear system of equations:
ax+by+z=1
x+aby+z=b
x+by+az=1
for a,b\in\mathbb R
and plot equations and solutions in cases where the system is consistent.
-Cramer's rule
-Kronecker-Capelli's theorem
Using Cramer's rule, we find the determinant of the system and determinant for each variable:
D=b(a-1)^2(a+2)
D_x=b(a-b)(a-1)
D_y=(a-1)(ab+b-2)
D_z=b(a-1)(a-b)
For b\neq 0 \land a\neq 1\land a\neq -2\Rightarrow D\neq 0 system has unique solution:
(x,y,z)=\left(\frac{a-b}{(a-1)(a+2)},\frac{ab+b-2}{b(a-1)},\frac{a-b}{(a-1)(a+2)}\right).
How to plot the equations with intersection (point) in this case?
Second case, a=1.
Solvind the system using Kronecker-Capelli's theorem gives:
b=1\Rightarrow infinitely many solutions.
b\neq 1\Rightarrow the system is inconsistent.
This gives (x,y,z)=(1-y-z,y,z).
How to plot the equations with intersection (line) in this case?
Third case, a=b=-2\Rightarrow infinitely many solutions.
(x,y,z)=\left(z,\frac{-z-1}{2},z\right).
I didn't check the correctness of your result, but assuming all is right :
If it has a unique solution, so it's a point.
gruba said:
This gives (x,y,z)=(1-y-z,y,z). How to plot the equations with intersection (line) in this case?
That means that the solution verifies ## x+ y + z - 1 = 0 ## when ##x,y,z## describe ##\mathbb{R}^3##.
It's a plane passing through (1,0,0), (0,1,0), and (0,0,1).
We already discussed that in length yesterday :mad:
Likes gruba
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 28 ·
