Math Jeans
- 349
Drop a particle from the Earth's surface down a mineshaft to a depth h. Show that in this case there is no southerly deflection due to the variation of gravity and that the total southerly deflection is only
[tex]\frac{3}{2}\frac{h^2\omega^2}{g}sin(\lambda)cos(\lambda)[/tex]
g is defined at ground level.
The southerly deflection from above ground is given by:
[tex]C_i\frac{h^2}{g}\omega^2sin(\lambda)cos(\lambda)[/tex]
for individual forces where:
The Coriolis force to second order: [tex]C_1=\frac{2}{3}[/tex]
The variation of centrifugal force with height: [tex]C_2=\frac{5}{6}[/tex]
The variation of gravitational force with height: [tex]C_3=\frac{5}{2}[/tex]
I figured out that without the gravitational force attached, the equation given clearly turns into the equation that is desired.
However, I have been unable to figure out how the gravitational force would effect the deflection, and why falling through the Earth (reduction of gravity) would cause a cease of southernly deflection as opposed to falling to the Earth (increase of gravity).
