PMA and High RPM from a turbine
In summary, a gas turbine can be used to create high amperage electrical energy from a turbine burning biodiesel. High current will likely destroy the batteries, but throttling down the turbine or using a reducing gear can mitigate the risk.
sounder
PMA and High RPM from a turbine...
Hey Forum,
I am working on a plan to build a recharging setup. What I want to do in theory is take a jet turbine or a smaller RC turbine that burns bio diesel and turns at around 60,000 RPM. I want to take this high speed rotation into a chain or belt system spinning 1-4 PMAs(Permanent Magnet Alternators). This generated electrical energy will then be stored in large super capacitors or 15 deep cycle batteries.
What I want to know, first is this possible? Also, I am thinking that really high currents will destroy the batteries, hence the use of the super capacitors. Can I still recharge the batteries from the Capacitors? I have found some PMAs that will put out 100 amps, but the website states that the horse power is unknown, so its just a reference. I don't know what the HP would be for a turbine, so I would just have to use an average number. I am thinking that there will be large amounts of heat, and the possibility of burning up the PMAs at that speed, so maybe throttling down the turbine, or using a reducing gear?
I want to calculate how long it would take to recharge the battery bank from this type of setup burning the bio diesel into the turbine. This is possible, but I need help assuming some values.
Lets figure: Battery - 225AH X 15 (# of batteries)
I could find very little on super capacitors and PMA specs.
Thanks,
Sounder
The horsepower for the turbine will vary by type and will be available from the OEM. I'd definitely use a reduction gear to drop the rotational speed. If you vary the speed you'll vary the output of the generator. All gas turbine generator sets I've encountered are constant speed turbines.
BTW gas turbines are already used for this application (e.g. ship power, industrial plants, power stations).
CS
Thanks for the reply!
Yea, I figured that high rpm would create a massive problem in heat with traditional materials in a generator.
I have tried looking at the larger applications, and how it could be miniaturized, but I still want to know what kind of amps could realistically be generated by a gas turbine? Spinning an alternator or something similar at 20k rpm? That could then be calculated what time it would take to recharge a battery bank.
Regards,
Sounder
1. What does PMA stand for?
PMA stands for Permanent Magnet Alternator. It is a type of alternator that uses permanent magnets instead of electromagnets to generate electricity.
2. How does a PMA affect the RPM of a turbine?
A PMA can affect the RPM of a turbine by regulating the amount of electricity produced. As the turbine spins and the PMA generates electricity, the load on the turbine increases, causing it to slow down. This decrease in RPM can be controlled by adjusting the load on the PMA.
3. Can a turbine operate at high RPM with a PMA?
Yes, a turbine can operate at high RPM with a PMA. The PMA is designed to handle high speeds and can generate electricity even at high RPMs.
4. What are the advantages of using a PMA in a turbine?
One advantage of using a PMA in a turbine is that it eliminates the need for a gearbox. This reduces the complexity and maintenance requirements of the turbine. Additionally, a PMA can operate at higher efficiencies compared to other types of generators.
5. Are there any disadvantages of using a PMA in a turbine?
One potential disadvantage of using a PMA in a turbine is that it may be more expensive than other alternatives. However, the cost may be offset by the increased efficiency and reduced maintenance costs in the long run.
  • Electrical Engineering
  • General Engineering
  • Mechanical Engineering
