Pneumatic/hydraulic energy storage
7 replies · 2K views · last reply
physea
Hello! Are there any systems that you can store rotational energy into pneumatic or hydraulic energy? Let's say we have a rotational shaft. How can I take energy from it and store it as pneumatic or hydraulic energy? And then re-use it?
I suppose you could run a compressor from your shaft that will compress air into a tank. Then you can use the compressed air however you want.
Would that work with liquids? Any hydraulic system to have a look?
of course ... in use every day on heavy construction industry machines ... dozers, grader, excavators etc
You won't be able to compress a liquid very effectively, so that part won't work.
I know you could run a hydraulic system off of your shaft, but I don't know how you would store energy in a hydraulic system. Hydraulics are usually used to transfer the power from a power source, such as an engine or motor, to a location where that power is needed to do work, without needing mechanical linkages. However, if you're designing a system that can stored energy from a shaft, then you could incorporate hydraulics to get the energy back out of wherever you stored it.
You could pump the liquid uphill and store energy in GPE.
Google hydraulic hybrid truck for applications of energy storage in hydraulic systems. The energy is stored in an accumulator, search term is hydraulic accumulator.
