MHB Finding the Point of Intersection: Is (-2, -2.5) the Solution?
  • Thread starter Thread starter nicholar1
    Intersection Point
To find the point of intersection of the lines represented by the equations 4y = x - 8 and 2y = 3x + 1, simultaneous equations can be solved using substitution or elimination. By rewriting the second equation as 4y = 6x + 2, both equations can be set equal to each other. Solving the resulting equation x - 8 = 6x + 2 yields x = -2. Substituting x = -2 back into either equation confirms that y = -2.5, establishing that the point of intersection is indeed (-2, -2.5).
nicholar1
Hi,
I am looking for some help on how you find the point of intersection of the following two lines:
4y = x - 8
2y = 3x + 1
Thanks for any help.
/Nichola
Mathematics news on Phys.org
nicholar1 said:
Hi,
4y = x - 8
2y = 3x + 1
/Nichola
Hi Nichola
The intersection will be at the point where the equations are equal. Are you familiar with solving simultaneous equations either by substitution or elimination?
Multiply the second equation by 2:
[math]4y = 6x+2[/math]
You can then subtract this equation from the first one to eliminate y
SuperSonic4 said:
Hi Nichola
Hi,
No I have never done simultaneous equations before, that's where I'm getting confused, how they work together.
nicholar1 said:
Hi,
4y = x - 8
2y = 3x + 1
/Nichola
nicholar1 said:
Hi,
Welcome to MHB Nichola! :)
We can multiply the second equation by 2 as Supersonic suggested.
That is, we start with:
$$2y = 3x + 1$$
and we end up with
$$4y = 6x + 2$$
Now we can see that according to the first equation $4y=x-8$ and according to the rewritten second equation we also have that $4y=6x+2$.
Since both are equal to $4y$ it must be that $x-8$ is equal to $6x+2$.
How would you solve the equation $x-8 = 6x+2$?
$$2y = 3x + 1$$
and we end up with
$$4y = 6x + 2$$
So to solve the equation $x-8 = 6x+2$ we:
Add 8 to both sides: $x = 6x+10$
Subtract 6x from both sides: $-5x = 10$
Divide both sides by -5: $x = -2$
So, substituting x = -2 into the equations give:
$4y = -2 - 8 = -10$
$2y = 3 x (-2) + 1 = -5$
So dividing -10 by 4 or -5 by 2 gives -2.5.
So does that mean the point of intersection is (-2, -2.5)?
Thanks for the help guys :)
/Nichola
$4y = -2 - 8 = -10$
/Nichola
Let's verify...
Substiting (-2, -2.5) in:
\begin{aligned}4y &= x - 8 \\
2y &= 3x + 1
\end{aligned}
gives:
\begin{aligned}4 \cdot -2.5 &= -2 -8 \\
2 \cdot -2.5 &= 3 \cdot -2 + 1
\end{aligned}
simplifying:
\begin{aligned}-10 &= -10 \\
-5 &= -5
\end{aligned}
We have a match, so this is the correct solution! (Happy)
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
