Pointer Momentum of a Measuring Apparatus
  • Thread starter Thread starter SheikYerbouti
    Measuring Momentum
SheikYerbouti
I am writing a paper on the problem of measurement and I am stuck on what the pointer momentum corresponds to physically. The coupling of the pointer momentum with the observable being measured is used to define the interaction Hamiltonian between the measuring apparatus and the system being measured. I understand that the observable conjugate to the pointer momentum is the pointer coordinate/read-out and that the pointer momentum generates the translations in for this coordinate. Is this all that there is to the pointer momentum, or does it correspond to something else as well?
Yes - that's how generalised measurements are arrived at:
http://www.quantum.umb.edu/Jacobs/QMT/QMT_Chapter1.pdf
Well that's all there really is to the momentum operator - but what exactly you mean by 'pointer momentum' in this context I am not sure.
Thanks
Bill
By the pointer momentum, I am referring to the observable of the measuring apparatus that is coupled to the observable that is being measured in the system. I don't know if that helped at all, so here is a link that explains the setup: http://www.theory.caltech.edu/people/preskill/ph229/notes/chap3.pdf. It goes into the model on the second page and I am referring to the P operator. When we discuss the momentum of a particle, there is more to it than simply being the generator of coordinate translations. I was just wondering if there was something similar going on for the pointer momentum in that there was a deeper, manifestly physical interpretation or if it simply is a generator of translation.
Not so sure about that.
See chapter 3 - Ballentine - Quantum Mechanics - A Modern Development.
It's constrained by the fact probabilities are frame invariant.
Symmetry is its fundamental basis - symmetries implied by probability invariance in QM - symmetries implied by Lagrangian invariance in classical mechanics.
IMHO there is nothing deeper going on - its the magic and mystery of symmetry in physics.
Symmetry tells us what the momentum operator is. But its relation to the measurent problem is another matter - as it is for any observable in QM.
I know that paper you linked to and it is good.
However for understanding the measurement problem in light of modern developments in decoherence I think the following is better:
http://philsci-archive.pitt.edu/5439/1/Decoherence_Essay_arXiv_version.pdf
It emphasises the crucial difference between improper and proper mixed states.
An even better reference is Decoherence and the Quantum to Classical Transition by Schlosshauer
https://www.amazon.com/dp/3540357734/?tag=pfamazon01-20
Its my go-to book on such things.
Thanks
Bill
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
I am looking at the Laughlin wave function and it contains the term $$\prod_{j<k}^{N}\left(z_j-z_k\right)^q$$ In Wikipedia the lower index on ##\Pi## is ##1\le i<j\le N## and there is no upper index. I'm not sure what either mean. For example would $$\prod_{j<k}^{N}\left(z_j-z_k\right)^q=\prod_{k=2}^{N}\left[\prod_{j=1}^{k-1}\left(z_j-z_k\right)^q\right]?$$ (It seems that ##k## cannot be 1 because there would be nothing to multiply in the second product). I'm not sure what else the...
