C/C++ Is there a more efficient way to use member functions with GSL routines in C++?
  • Thread starter Thread starter Wallace
    Function Member
Using Gnu Science Libraries (GSL) in C++ often requires providing function pointers for routines, which poses a challenge when the desired function is a member of a class. Member function pointers differ from regular function pointers, complicating their direct use with GSL. To work around this, developers typically create wrapper functions that utilize a void pointer to access the class instance via the 'this' keyword, though this approach can lead to naming conflicts in larger projects. While casting member function pointers to regular function pointers is not effective due to differing calling conventions, using static member functions can provide a cleaner alternative. Overall, finding efficient methods to integrate member functions with GSL routines remains a common concern among C++ developers.
Wallace
I'm even sure I'm using the correct terminology, but I'm hoping someone can help me with a common problem I encounter.
I frequently use the Gnu Science Libraries (GSL) in my C++ code to do various numerical grunt work. Commonly I need to provide a pointer to a function for a GSL routine to work (e.g. pointer to a function that GSL will find the minimum of for instance). Now, often the function I'm interested in is a member function of some object. But I can't provide a pointer to that, since the pointer to a member function is not the same as a pointer to a function.
Instead, I restort to making small wrapper functions that take a void pointer as the input, and send the relevant object to the class using the 'this' keyword. This way the function can access the members of that object (I make this function a friend of the relevant class).
These little wrapper functions are annoying though, since because they are free standing I have to make sure I use unique names, which can be annoying when re-using code and for big projeccts.
What I'd like to know is whether there is a better way to do this, for instance can you somehow cast the pointer to the member function to be a pointer to a function and just send that to the GSL routines? Sorry if this doesn't make much sense, I 'learned' C++ in a very ad hoc way, so I get the terminology mixed up sometimes.
Technology news on Phys.org
Even if you were to cast the pointer to the member into the pointer to a normal function successfully (using reinterpret_cast or some such contraption), things wouldn't work well, because class member functions and normal functions have different calling conventions, and GSL wouldn't know to pass "this" pointer to your function.
You can pass a pointer to a static class member, that's almost the same as making a wrapper, but a bit neater.
Thanks, perfect solution!
Thread 'Is this public key encryption?'
I've tried to intuit public key encryption but never quite managed. But this seems to wrap it up in a bow. This seems to be a very elegant way of transmitting a message publicly that only the sender and receiver can decipher. Is this how PKE works? No, it cant be. In the above case, the requester knows the target's "secret" key - because they have his ID, and therefore knows his birthdate.
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
