Poisson counting process & order statistics
3 replies · 5K views
kingwinner
Theorem: Let {N(t): t≥0} be a Poisson process of rate λ. Suppose we are given that for a fixed t, N(t)=n. Let Ti be the time of the ith event, i=1,2,...n.
Then the (conditional) density function of Tn given that N(t)=n is the exactly the same as the density function of X(1)=min{X1,X2,...,Xn}, where X1,X2,...,Xn are i.i.d. uniform(0,t).
(similar result holds for the density of the other Ti's)
Example: Let {N(t): t≥0} be a Poisson process of rate λ. The points are to be thought of as being the arrival times of customers to a store which opens at time t=T. The customers arriving between t=0 and t=T have to wait until the store opens. Let Y be the total times that these customers have to wait. Calculate E(Y).
Solution:
N(T)=N
N(T)~Poisson(λT)
(T1,T2,...,TN) is equal in distribution to (X(1),X(2),...,X(N)), where the order statistics are coming from X1,X2,...,XN which are i.i.d. uniform(0,T).
=> T1+T2+...+TN is equal in distribution to X(1)+X(2)+...+X(N) = X1+X2+...+XN
E(Y)=E(total waiting time)
=E[(T-T1)+(T-T2)+...+(T-TN)]
=E(NT) - E(T1+T2+...+TN)
=T E(N) - E(X1+X2+...+XN)
=T E(N) - E[E(X1+X2+...+XN|N)]
=T E(N) - E[N E(X1)]
=T E(N) - E[N T/2]
=T E(N) - (T/2) E[N]
=(1/2) T E(N)
=(1/2) T λT
In the theorem, we require N(t)=n where n is a FIXED number. But throughout the solution (for example when they calculate E[X1+X2+...+XN]), N(t)=N is being treated as a RANDOM VARIABLE rather than a fixed number. Why? If N is a random variable, I don't think the theorem above applies...will we still have that TN is equal in distirbution to X(N)? Why or why not?
In other words, I am questioning the statement "(T1,T2,...,TN) is equal in distribution to (X(1),X(2),...,X(N))" in the solution of the example. Here N itself is a random variable, but in the theorem it is required to be fixed (in the theorem we're GIVEN the value of N(t))...
Can someone please explain? Any help is greatly appreciated!:)
That's right, you'll need the theorem that the joint distribution of the arrival times conditional on N is the same as the order stats of the uniform distribution.
kingwinner said:
...Here N itself is a random variable, but in the theorem it is required to be fixed..
To apply the theorem correctly, take the expectation of the conditional expectation.
If the theorem above does not apply in our problem, is it still true that "(T1,T2,...,TN) is equal in distribution to (X(1),X(2),...,X(N))" ?(here N=N(T) is a random variable, I believe) Why or why not?
