I Does Zero Potential at a Point Imply Zero Charge Density?
  • I
  • Thread starter Thread starter aaaa202
Zero potential at a point does not imply zero charge density at that point due to the nature of electrostatic potential. Poisson's equation indicates that the Laplacian of the potential is related to charge density, but the potential's value can be shifted arbitrarily without affecting the Laplacian. Therefore, a potential of zero at a specific point does not provide definitive information about the charge density. The discussion emphasizes that the potential's absolute value lacks physical significance, as it can be adjusted by a constant. Thus, one cannot conclude that zero potential equates to zero charge density.
aaaa202
Poissons equation for the electrostatic potential is:
2φ = -ρ/ε
My question is simple: If φ=0 at a point (x,y,z) can we then conclude also that ρ is zero at that point?
The value of the potential at a single point has no physical meaning - you can always arbitrarily shift it by a reference value.
More concretely, ##\nabla^{2}\left(\varphi + \alpha\right) = \nabla^{2}\left(\varphi\right)## for any constant ##\alpha##.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
