Polar Coordinates and Conservative Vector Fields
The discussion centers around demonstrating that the vector field F is conservative on R² excluding the non-positive x-axis. Participants explore the use of polar coordinates to express points in the domain D, highlighting the need for a correct interpretation of the angle θ based on the signs of x and y. There is confusion regarding the definitions of θ, with suggestions that it should account for the sign of y when x equals zero. A counter-example is presented to show that F is not conservative even when avoiding the non-positive x-axis, as the integral over a specific closed path does not equal zero. The conversation emphasizes the importance of accurately parameterizing the vector field and clarifying the definitions used in the problem.
TranscendArcu
Let F = <-y/(x2+y2, x/(x2+y2>. Recall that F was not conservative on R2 - (0,0). In this problem, we show that F is conservative on R2 minus the non-positive x-axis. Let D be all of R2 except points of the form (-x,0), where x≥0.
a) If (x,y) is included on D, show that it is possible to express (x,y) in polar coordinates (r,θ) such that x=r*cosθ and y=r*sinθ, where θ can be chosen such that θ equals,
{arctan(y)/x if x>0
{pi/2 if x=0
{pi + arctan(y)/x if x<0.
It seems to me that if arctan(y) is bounded between -pi/2 and pi/2, then by taking the limits as x goes to "positive" zero and infinity, we see that θ is bounded, by the first definition, between 0 and infinity.
θ = pi/2 if x=0 simply includes all points along the y-axis.
Similarly, by taking limits, we find that, by the third definition, is bounded between pi and negative infinity. Since (x,y) necessarily lies on D, we need not worry that (x,y) is on the non-positive x-axis.
So what we have here is a θ capable of ranging from negative infinity to infinity. If we choose an arbitrary r, then our range of θ will allow us to reach any (x,y).
Personally, I think that this is either wrong or that there is more convincing way of doing the problem.
You seem to have made numerous typos. It shouldn't be arctan(y)/x. It should be arctan(y/x). Additionally, is θ suppose to equal pi/2 regardless of the sign of y?
I think part of the issue here is that the problem, for me, was ambiguously worded. All it said was: theta equals
{arctan y/x if x>0
{pi/2 if x=0
{pi + arctan y/x if x<0.
I interpreted this as arctan (y)/x, but I can see how arctan (x/y) could also be an interpretation. In any case, I still don't really know how to begin the problem, especially since my original interpretation is, apparently, incorrect. There is no mention of y-signs in the problem.
I think the correct definition of \theta should be
\theta = \begin{cases}<br /> \arctan (y/x) &amp; \text{if }x&gt;0 \\<br /> \arctan (y/x)+\pi &amp; \text{if }x&lt;0 \\<br /> \pi/2 &amp; \text{if } x=0 \text{ and } y&gt;0 \\<br /> -\pi/2 &amp; \text{if } x=0 \text{ and } y&lt;0<br /> \end{cases}The reason I think you need to consider the sign of y when x=0 is because r is typically assumed to be positive. If r>0 and θ=+π/2 when x=0, there's no way to express a point like (0,-1) in polar coordinates.
Okay, I think that makes sense. I guess if you let r be negative, then it could no longer have the interpretation as the radius. In any case, could you please tell how to begin to show that theta can be selected in this way? I don't think my method of taking limits was correct or legitimate.
I think I have a counter-example to this problem. I will show that F is not conservative on the closed path r(t) = <cos(t) + 2, sin(t) + 2>. This path lies entirely in the first quadrant, and therefore meets the condition that the path does not pass over the non-positive x-axis. I will show that that the integral over r(t) of F(x(t),y(t)) dot r'(t) dt does not equal zero.
r'(t) = <-sin(t),cos(t)> and F(x(t),y(t)) = <-sin(t),cos(t)>.
Taking the dot product of the simply gives 1.
The integral from 0 to 2*pi of 1 dt = 2*pi.
Since 2*pi does not equal zero, F is not conservative, even when the non-positive x-axis is excluded.
Gah! I don't get this problem at all!
Your expression for \vec{F} should be \vec{F} = \langle -\frac{\sin \theta}{r},\frac{\cos \theta}{r}\rangle.
But I'm not parameterizing F by x=r*cos(theta). I'm using x=cos(t). Why shouldn't this parameterization work properly?
I'm not sure exactly what you're supposed to show. You probably need to show that for any (x,y) in D, you can calculate θ and that r cos θ equals x and r sin θ equals y with an appropriately chosen r.
You have
\begin{align*}
x(t) &= 2+\cos t = r(t) \cos\theta(t) \\
y(t) &= 2+\sin t = r(t) \sin\theta(t)
\end{align*}The parameter t isn't the same as θ.
  • · Replies 19 ·
