Polar Coordinates, intersection of a cylinder with a spher
The discussion focuses on calculating the volume of the solid formed by the intersection of the cylinder defined by the equation r = a cos(θ) and a sphere of radius a. The polar region is defined as D = { (r, θ) | -π/2 ≤ θ ≤ π/2, 0 ≤ r ≤ a cos(θ) }. The initial attempt at solving the volume using the double integral V = 2 * ∫_{-π/2}^{π/2} ∫_{0}^{a cos(θ)} r√(a² - r²) dr dθ led to an incorrect volume of 2πa³/3. The error was identified as stemming from the integration of an odd function, which resulted in a zero value. The correct volume calculation, after applying symmetry and integrating from 0 to π/2, yields V = 4/3 a³ * ((3π - 4)/6), approximately 29% of the sphere's volume.
  • Understanding of polar coordinates and their applications in volume calculations.
  • Familiarity with double integrals in multivariable calculus.
  • Knowledge of the properties of odd and even functions in integration.
  • Basic understanding of geometric shapes, specifically spheres and cylinders.
  • Study the application of polar coordinates in volume integrals.
  • Learn about the properties of odd and even functions in calculus.
  • Explore advanced techniques for solving double integrals.
  • Investigate the geometric interpretations of volume calculations involving intersections of shapes.
Students and educators in mathematics, particularly those studying calculus and geometry, as well as anyone involved in solving complex volume problems involving polar coordinates and integrals.
DarthRoni
Find the Volume of the solid that the cylinder ##r = acos\theta## cuts out of the sphere of radius a centered at the origin.
I have defined the polar region as follows,
$$D = \{ (r,\theta) | -\pi/2 ≤ \theta ≤ \pi/2 , 0 ≤ r ≤acos\theta \} $$
I will take f(x,y) as follows,
$$ f(x,y) = \sqrt{a^2 - x^2 - y^2} $$
Because of symmetry, I should be able to take the removed volume as double the double integral of f(x,y) over the region D.
$$ V = 2 *\int_{-\pi/2}^{\pi/2} \int_{0}^{acos\theta} r\sqrt{a^2 - r^2} \mathrm{d} r \mathrm{d} \theta $$
After solving this double integral, I keep ariving at ## {2\pi a^3}/3 ## Which I don't think makes sense because that would be half the volume of the sphere. What am I doing wrong?
Show your work after the above; we cannot tell where you went wrong if you don't show us what you did---in detail, step-by-step.
## V = -2/3 * \int_{0}^{2\pi} (a^2 - a^2 cos^2(\theta))^{3/2} - a^{3/2} d\theta ##
## \Rightarrow V = -2/3 * \int_{-\pi/2}^{\pi/2} a^3 (1- cos^2(\theta))^{3/2} - a^3 d\theta ##
## \Rightarrow V = -(2*a^3)/3 * \int_{-\pi/2}^{\pi/2} sin^3(\theta) - 1 d\theta ##
## \Rightarrow V = (2*a^3*\pi)/3 ##
Hope that's enough, any help with be very appreciated.
One obvious problem is the fact that ##\int_{-\pi/2}^{\pi/2} \sin^3 (\theta) \, d \theta = 0## because ##\sin## is an odd function. This, in turn, arises from the mistake of taking ##(1-\cos^2)^{3/2} = \sin^3##. The fact is that you started off with positive square roots, then got a 3/2 power via integration. In fact, ##\sqrt{1-\cos^2} = |\sin|##. You could have avoided all that by using symmetry to just integrate from 0 to ##\pi/2##, then multiply the result by 2.
Thank you very much, I see where I went wrong. After using your method, I arrived at a final answer of
##V = 4/3 a^3 *((3\pi - 4)/6) ##
which is about 29 percent of the sphere's volume. Makes more sense. Thanks again for your help!
  • · Replies 19 ·
  • · Replies 20 ·
