Polar Coordinates: Position of Particle at T/8
The problem involves determining the position of a particle in polar coordinates, given by the equation r(t) = acos(wt) i + bsin(wt) j, at a specific time t equal to 1/8 of the time period T. The discussion centers around the conversion of this position into polar coordinates and the associated calculations.
  • Participants discuss the transformation of the particle's position from Cartesian to polar coordinates, questioning the correctness of their calculations and the resulting angle. Some express confusion regarding the derivation of the polar equation and the relationship between angular components and velocity.
The discussion is ongoing, with participants providing insights and questioning each other's reasoning. Some have offered guidance on deriving the polar equation and clarifying the relationship between angular velocity and the components of motion, while others are still grappling with specific aspects of the problem.
There are indications of confusion regarding the definitions of angular components and the specific requirements of the problem, particularly whether to express the results in terms of r(t) and v(t) versus r(θ).
vaibhav garg
1. The question
The position of a particle is given by r(t) = acos(wt) i + bsin(wt) j. Assume a and b are both positive and a > b. The plane polar coordinates of a particle at a time t equal to 1/8 of the time period T will be given by _
at t = T/8 the value of wt=π/4.
therefore in Cartesian coordinates the vector is r= a/√2 + b/√2.
so in polar coordinates this transforms to r = √(a2 + b2)/2 and tanθ = b/a. My answer does not match with the given one. Also if we were to write the polar equation of the curve how would that follow ?
Hi,
Strange. Don't see anything wrong. In what respect does your answer not match with the given one ?
BvU said:
Hi,
The angle does not match. tanθ = b/a√2 is given
Also this is one of the part of the question, and I still can't understand how to wite the polar equation for this curve
Still strange. Where would the ##\sqrt 2## come from ?
Your ##\tan\theta## matches the expression here (##\tan t=1##).
And the answer for the polar equation is right in the next paragraph :rolleyes:
You have $$r\cos \theta = a \cos \omega t$$and $$r\sin \theta = b \sin \omega t$$
Just solve for r and ##\theta##
I calculated the polar equation to be r = √(a2cos2(wt) + b2sin2(wt)) r^
and then I differentiated it to get the velocity as v = ((b2 - a2)sin(wt)cos(wt)w)/√(a2cos2(wt) + b2sin2(wt)) r^ + √(a2cos2(wt) + b2sin2(wt))w θ^
Is this wrong ?
vaibhav garg said:
Is this wrong ?
It looks correct. For aesthetic purposes, I would go to the double angle formulas:
$$2\sin \omega t\cos \omega t=\sin2\omega t$$
$$\cos^2 \omega t=\frac{1+\cos 2\omega t}{2}$$
$$\sin^2 \omega t=\frac{1-\cos 2\omega t}{2}$$
Are we sure the exercise composer wants r(t) and v(t) instead of ##r(\theta)## when asking for the polar form ?
Oops. I don't confirm your coefficient of ##\hat{\theta}##. I get ##\frac{\omega ab}{r}##.
that is the problem I have been having, I can't figure out as to why I am not getting the correct angular component
The angular component is ##rd\theta/dt##, not ##r\omega##. In this problem ##d\theta/dt## is not the same thing as what they call ##\omega##. You need to be able to show that ##\frac{d\theta}{dt}=\frac{\omega ab}{r^2}##.
$$\tan \theta = \frac{b}{a}\tan \omega t$$
$$\sec^2 \theta \frac{d\theta}{dt}=\frac{b\omega}{a}\sec^2\omega t$$$$r\cos \theta=a\cos \omega t$$
Combine 2nd and 3rd equations to eliminate ##\sec \theta##.
  • · Replies 30 ·
  • · Replies 22 ·
