How Is Polar to Rectangular Conversion Used in Complex Number Calculations?
The discussion revolves around the conversion of complex numbers from polar to rectangular form and back, specifically in the context of a calculation involving the expression 208L0 - 2.5L90 x 27.42L36.9. The original poster struggles to achieve the correct result of 255.12L-12.4, despite attempting various methods, including converting to rectangular form for subtraction and then back to polar form. Participants point out arithmetic errors and the importance of correctly applying signs during calculations, emphasizing that multiplication is easier in polar form while addition and subtraction are simpler in rectangular form. Ultimately, the correct approach involves careful attention to detail in calculations and proper application of mathematical principles.
Dcmagni
Thread moved from the technical forums to the schoolwork forums
I'm having trouble trying to calculate how the answer below was achieved from an example i have seen, see below:
208L0 - 2.5L90 x 27.42L36.9 which is then calculated to 255.12L-12.4.
I have tried converting everything to rectangular form, subtract where required and the convert back to polar form to multiply. To be honest I have tried every way and can not figure this out. Any help is appreciated.
Welcome to PF.
I'm having a hard time parsing what you wrote. Are your "L" characters supposed to be indicating angles? ( ∠ )
And is the "x" character meant to represent some kind of multiplication (cross product?)
Welcome to PF.I'm having a hard time parsing what you wrote. Are your "L" characters supposed to be indicating angles? ( ∠ )
Yes apologies, it would not let me enter the angle sign for some reason. Also the 'x' is multiplication
Thank you
Thank you
Are these complex numbers?
If you want help, you must show all the steps of your calculations in detail. Using my HP50 calculator which can do complex arithmetic I get a result of 255.11795 < -12.408174
Can you show us some of your work so we can check it over for mistakes? You should be able to copy/paste the angle symbol that I posted to make the notation clearer.
Likes Dcmagni
So far I have the understanding that subtraction is easier in polar form and multiplication in rectangular form, I need to transform into rectangular form.
I have first multiplied 2.5∠90 x 27.42∠36.9.
= 68.55∠126.9 (I have multiplied the polar magnitude and addition for the angle)
Then I have converted 208∠0 - 68.55∠126.9 into rectangular form.
208∠0 =
(208)(cos0) = 208
(208)(sin0) = 0
Therefore = 208+j0
-68.55∠126.9 =
(68.55)(cos126.9) = -41.16.
(68.55)(sin126.9) = j54.82
Therefore = -41.16+j54.82
Resulting in 208+j0 - 41.16+j54.82.
Subtracting to me gives a result of: 166.84 - j54.82 (Subtracting the magnitudes and the angles)
I have then converted 166.84 - j54.82 back to polar form.
Magnitude = √166.84^2 - 54.82^2
= 157.57
Angle = arctan -54.82/166.84
= -18.19
Therefore my final result is 157.57∠-18.19. Which is not the same as the result from the example that was given.
You've added these two complex numbers. Whereas, you were supposed to subtract one:
Sorry I don't understand what you mean, where have I added?
I have subtracted as follows:
208 - 41.16 = 166.84
j0 - j54.82 = -j54.82.
Therefore resulting in 166.84 - j54.82
What's ##208 - x## when ##x = -41##?
249? If so then this answer is still incorrect as the answer gives 255.12
That's just the real part.
208∠0 =
(208)(cos0) = 208
(208)(sin0) = 0
Therefore = 208+j0
-68.55∠126.9 =
= 157.57
= -18.19
When you did this:
"-68.55∠126.9 =
Therefore = -41.16+j54.82"
You forgot to apply the leading minus sign which was at the very beginning.
The correct result is: +41.16-j54.82
You need to include parentheses where appropriate. Next you can either subtract (-41.16+j54.82), or you can add (+41.16-j54.82), which would give:
"Resulting in 208+j0 -(-41.16+j54.82).
Subtracting to me gives a result of: 249.16 - j54.82 (Subtracting the magnitudes and the angles)"
You are not subtracting magnitudes and angles. You are subtracting real parts and imaginary parts.
Converting to polar gives: 255.12 ∠-12.41
Likes PeroK
Note that if ##z = z_1 - z_2z_3##, then:
$$|z|^2 = r_1^2 + r_2^2r_3^2 - 2r_1r_2r_3\cos(\theta_1 - \theta_2 - \theta_3)$$
The Electrician said:
When you did this:
"-68.55∠126.9 =
Ok thank you for your reply and feedback.
So the process I am using is correct which is a good start. Looking at what you have put and inputting the correct figures I have gotten.
208 + j0 + 41.16 - j54.82 gives 241.16 - j54.82 (As you have suggested above)
Converting to polar:
√241.16^2 + (-54.82^2)
= √58158.15 + (-3005.23)
= √55152.92
=234.85
arctan 54.82/241.16 = -12.81
= 234.85 ∠ -12.81
I just do not understand where I am going wrong.
Negative numbers square to positive numbers!
Alternatively, with ##z = a+bj##, we have:
$$|z|^2 = a^2 + b^2 \ne a^2 - b^2$$
Even still.
= √58158.15 + (+3005.23)
= √61163.38
=247.31
arctan 54.82/247.31 = -12.49
= 247.31 ∠ -12.49
I have just tried this after reading another article but it still doesn't seem to come up with the right answer.
Dcmagni said:
Even still.
= √61163.38
=247.31
= 247.31 ∠ -12.49
You're just making basic mistakes like typing ##241## instead of ##249##.
Why not put the calculation on a spreadsheet?
r_1theta_1r_2theta_2r_3theta_3xyrtheta
208​
0​
2.5​
1.570796​
27.42​
0.644026​
249.1588​
-54.8184​
255.1179​
-12.4082​
You are right and thank you for all your help. Heads jammed juggling this and work at the same time. Again, appreciate your help.
Likes PeroK
= √55152.92
=234.85
= 234.85 ∠ -12.81
You have a simple arithmetic error. Are you doing your arithmetic by hand? Don't you have a calculator or a calculator app for your phone?
You have:
"208 + j0 + 41.16 - j54.82 gives 241.16 - j54.82 (As you have suggested above)"
but it should be:
"208 + j0 + 41.16 - j54.82 gives 249.16 - j54.82 (As you have suggested above)"
Edit: Sorry, I just noticed that PeroK already pointed this out.
I can see that the original question has already been addressed. Here I would like to comment on the statement mentioned in the above quote. I think, as demonstrated below, it should be,
The multiplication of two complex numbers is easier in polar form and addition/subtraction of two complex numbers is easier in rectangular form.​
Let’s first represent a complex number in polar form with (r, θ). We have
z2 = (2.5, 90)​
z3 = (27.42, 36.9)​
z2×z3 = (2.5*27.42, 90+36.9) = (68.55, 126.9)​
[See Eq. (3.11) of Complex variables.]​
Let’s next represent a complex number in rectangular form with (x, yi), where i = sqrt(-1).
Then
z1 = (208, 0i)​
z2×z3 = [68.55*cos(126.9), 68.55*sin(126.9) i] = (-41.16, 54.82i)​
z1 - z2×z3 = (208+41.16, 0i-54.82i) = (249.16, -54.82i)​
Convert it into polar form we have:
z1 - z2×z3 = (255.12, -12.41)​
Likes berkeman
10K
13K
  • · Replies 17 ·
  • · Replies 19 ·
