Pontential energy in a 4-particle system
  • Thread starter Thread starter Oldblood
    Energy System
The discussion focuses on calculating the potential energy of a system of four particles, each with mass M, arranged in a square configuration with side length d. The gravitational force acting on each particle is derived from the contributions of the other three particles, leading to a gravitational field expressed as g(d) = GM^2/(sqrt 2 * d)^2 + (sqrt 2 * GM^2)/d^2. The user attempts to integrate this field to find the potential energy for each particle and then multiplies by four to obtain the total potential energy. However, the resulting expression, -GM^2*(2 + 4sqrt 2)/d, is identified as incorrect, prompting a request for assistance in identifying the error. The goal remains to accurately calculate the potential energy in the specified four-particle system.
Oldblood
Find the potential energy in a system being 4 particles, each with mass M forming a square with sides d.
Newtons law of gravity
First I was trying to find the gravitatinal field as a function of d. I soon realized that this is a field in 1 dimension, along the diagonal of the square. 1 particle will feel a force from the 3 others and the force will be parallel to the diogonal of the square. From the furthest particle a particle will feel the force GM^2/(sqrt 2 *d)^2. From the sum of the 2 others it will feel (sqrt 2 *GM^2)/d^2 in the same direction. So we have that g (d)= GM^2/(sqrt 2 *d)^2+(sqrt 2 *GM^2)/d^2, where G is the gravitational constant. Then I simply just integrated this with respect to d to find the potential energy . I am guessing this gives me the potential energy for each particle, so to find the total energy I multiplied by 4. This did gave me total potential energy= - GM^2*(2+4sqrt 2)/d which is wrong. Where did I go wrong?
I appreciate any help. The goal is to calculate the potential energy in a 4 particle system making up a square
anyone?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
