Portion of Chromosome Copied with Limited dTTP
  • Thread starter Thread starter whamola411
dTTP is essential for DNA synthesis, with concentrations typically in mM, while chromosomes exist in pairs. The discussion estimates that with an initial dTTP concentration of 1 mM and no new production, only a fraction of the diploid chromosome set can be copied. The average chromosome size is approximated at 150 million base pairs, leading to calculations involving the molar weight of dTTP and nucleotides. The volume of a typical cell is estimated to be about 1 cubic micrometer, which is necessary to determine the total moles of dTTP available. The challenge lies in correlating these estimates to understand the extent of chromosome copying under limited dTTP conditions.
whamola411
1. dTTP is used in DNA synthesis. dTTP concentrations are mM, while a particular chromosome has only two copies. Estimate what fraction of the complete diploid set of chromosomes will be copied if at the start of DNA synthesis all new production of dTTP is blocked and the initial concentration of dTTp is 1 mM.
Several estimates need to be made. Explain where the estimates come from.
2. I don't have any relevant equations. This problem has no correlation to what we are learning in class, other than we are just starting to learn about DNA.
3. I started by finding out how big an average chromosome is and got 150*10^6 bp of 3*10^8 bases. Then I found the molar weight of dTTP to be 482.168 g/mol. I also found online that an average nucleotide weighs about 330 g/mol. Then I divided the total number of nucleotides by the MW for one nucleotide: 3*10^8/330 = 9.09*10^5 g/mol of nucleotides in one chromosome pair.
From here I don't know where to go because of the mM. The fact that there is a liter in the units throws me off completely.
First, you need to estimate the size of the cell in order to figure out how many moles of dTTP are in the cell.
Well, a typical cell is around 1 micrometer, or .001 mm. So, if we need volume, I would assume a cell to be roughly square and the volume to be .001*.001*.001 = 1*10^-9 mm^3
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
