I Positive Mass in the Lagrangian from Landau
The discussion centers on the requirement for positive mass in the context of the action integral in classical mechanics, as presented in Landau and Lifshitz's "Mechanics." It highlights that a negative mass would lead to a lack of a minimum in the action integral, particularly when considering rapid changes in velocity. The mathematical derivation shows that the second variation of the action is positive only if mass is greater than zero, confirming that the stationary point corresponds to a minimum for positive mass. There is a debate about the necessity of the action being a minimum, as Landau notes it only needs to be stationary, yet the context suggests a minimum is implied for positive mass. The conversation reflects on the complexities of deriving these principles and the challenges in finding clear explanations in other texts.
Oppie
Hello,
I'm sure most of you are already familiar with the book "Mechanics" by Landau and Lifshitz. There's a section that I do not understand.
In section 4 towards the end they mentions that "It is easy to see that the mass of the particle cannot be negative." They then give the argument that the action integral will not have a minimum if the mass is negative as can be seen if the particle leaves point 1 rapidly and approaches point 2 rapidly.
Can someone please elaborate on this?
Thanks for the bump.
Unfortunately, I am still at a loss.
Is it as simple as seeing that v^2 is always positive and therefore if m<0 then if v at the initial and terminal points are large then you cannot have a minimum for the action integral since it can be arbitrarily negative?
Thanks.
Let's calculate the 2nd variation of the action
$$A[x]=\int \mathrm{d}t \frac{m}{2} \dot{x}^2.$$
To that end we define
$$A[x,\eta]=A[x+\eta \delta x]=\int \mathrm{d} t \frac{m}{2} (\dot{x}+\eta \delta \dot{x})^2$$
and take the 1st and 2nd derivative wrt. ##\eta##:
$$\frac{\mathrm{d}}{\mathrm{d} \eta} A[x,\eta]=\int \mathrm{d} t m (\dot{x}+\eta \delta \dot{x})\delta \dot{x},$$
$$\frac{\mathrm{d}^2}{\mathrm{d} \eta^2} A[x,\eta]=\int \mathrm{d} t m \eta \delta \dot{x}^2,$$
Now you want for ##\eta=0## the action to be stationary, i.e., that ##x(t)## is the trajectory of the particle according to the Hamilton principle of least action. That means
$$\frac{\mathrm{d}}{\mathrm{d} \eta} A[x,\eta]|_{\eta=0}=\int \mathrm{d} t m \dot{x} \delta \dot{x} = -\int \mathrm{d} t m \ddot{x} \delta x \stackrel{!}{=}0 \; \Rightarrow \; m \ddot{x}=0.$$
Now the second derivative is always positive if and only if ##m>0## and thus the stationary point is indeed a minimum if and only if ##m>0##. Thus ##m## should be positive.
Thank you. I understand it now mathematically, if that makes sense.
My question now is, why require to action to be minimum? Landau and Lifshitz themselves note in a footnote that the action only needs to be stationary but now it seems that it has to be minimum for the mass to be positive.
Although it is not very important, when equations of motions are derived from the Hamilton principle (often incorrectly called principle of least action), most often the action calculated for the actual trajectory beginning in ##t_1,q_1## and ending in ##t_2,q_2## is a local minimum - all nearby trajectories obeying that constraint give higher action. There are exceptions, like trajectory of a billiard ball inside elliptic pool table, when going from one focus to another in given time through encounter with the wall; due to elliptic shape of the wall, all points of the wall lead the ball to the focus in the same time, so there is no single trajectory of least action.
In Landau, I think it is a circular reasoning, they claim mass needs to be positive based on the frequency of common situation that action has a minimum, and elsewhere they will say action has to be minimum for infinitesimally long trajectories because that gives the right equations for positive mass particle.
Thanks for the response. I tried looking at other books, etc. to see if I can find a better explanation on this, unfortunately there isn't, at least at all the places I searched.
Also, to add, Whittaker in his Analytical Dynamics gives a proof that the action is a minimum but this requires previous knowledge of the form of the kinetic energy. Anyway, I thought it was interesting and which in turn drove me nuts trying to reason out that the mass should be positive without knowing the form of the kinetic energy beforehand.
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
