Is a Rainbow Close to the Ground Possible? A Camera Optics Mystery
  • Thread starter Thalles
  • Tags
    Rainbows
In summary, the conversation discusses a video of a full circle rainbow that was considered a holy sign during a funeral in Tibet. The participants debate whether this type of rainbow is possible or if it could be a result of graphical manipulation. They also discuss the formation of rainbows and how they require certain conditions such as droplet-laden air and specific angles of light. The conversation also touches on other optical phenomena such as halos and ice-bows.
Thalles
I think this is the correct subforum for this question. If I'm wrong, please, forgive me.
Well, to the question.
I was browsing some wonderful pictures and videos and one crossed my vision and raised a doubt.
When I studied optics back in my school, I learned that the red wave stayed in the "outside" part of the rainbow, in the "outside" curvature. Also, I never saw a rainbow so close to the ground.
Is this possible or it's probably graphical working?
Many thanks for the attention.
Best wishes.
http://hyperphysics.phy-astr.gsu.edu/hbase/atmos/rbowpri.html#c2
see the secondary rainbow, you'll understand the formation of what you saw.
Then it's your first, don't make it your last :)
Likes Thalles
Best wishes.
What makes you think this is a rainbow? It could easily be a refraction off a glass or window.
Zz.
Because it was from a video and it was outdoors and the people were seeing the rainbow and all.
I've seen this many months ago, so I don't have the page anymore, sorry. I just kept this image from the video.
Rainbows seen so close to the ground are rare simply because of the geometry required.
The droplet-laden air must be the right angular distance from the sun (~40 degrees for primary bow, 50 degrees for secondary bow with inverted colours). In order for that to occur below the horizon line, the air must be pretty much at your feet.
This occurs when looking through a sprinkler or other misting apparatus, but rarely occurs in nature because you're usually looking at a volume of air in the distance and in the sky.
Rainbows are formed with the sun behind the observer and not in front, as that diagram implies. (I wonder where it came from originally as there are hundreds of the correct version if you look on google) There are only a few situations where the Sun is low enough in the sky and the observer high enough to see the invert of the circular bow. I have had spectacular views from an aeroplane of a complete circle and a few good ones in the back garden with a garden hose, getting just the correct angles.
You can get coloured halos around the sun - typically die to ice crystals in the atmosphere.
I think this video was filmed in Tibet, which would explain the angle.
Quite possibly; looking down into a valley with the Sun quite low in the sky.
You can see, from the lighting on the leaves, that the Sun is actually behind the camera.
Can secondary rainbows appear alone?
i don't see why not!If the sun is at 51° from the water droplets.
Likes Thalles
Yes, in theory.
Rainbows require the presence of droplet-laden air in the right place. If there is droplet-laden air 50 degrees away from the sun, but not 40 degrees away from the sun, then the primary bow will not be seen.
Likes Thalles
The two rainbows have no direct relationship. Neither is caused by the other. They require a number things to appear:
1. A bright, pointlike illumination source
2. A path from that source to the refraction area.
3. A volume of air at the refraction area containing suspended spherical droplets.
4. A path from the refraction area to your eye.
If there is a cloud in the way of the light illuminating the area responsible for the primary rainbow, you don't get the primary rainbow. If there are no droplets in the area responsible for the primary rainbow, you don't get the primary rainbow. If you hold your hand in front of your eye so that you can't see the primary rainbow, you won't see the primary rainbow. In all three cases you may nonetheless be able to see the secondary rainbow.
Likes Thalles and Suraj M
I found another video of the same rainbow. Turns out that this rainbow was considered a holy sign because it appeared during the funeral of one tibetan Lama
Here it is.
It's weird, but I don't think it's impossible.
No, that is very weird. (Assuming no tampering.)
A secondary bow occurring without a primary isn't hard to do over a short arc, because the pocket of droplet-laden air can be arbitrarily small, or in the wrong place, so only the secondary is formed. But - it forms only in a short arc. [see middle panel in highly technically-accurate simulation below]
But the secondary bow in the video is pretty much fully circular. How can you have a mass of droplet-laden air in a circle 50 degrees from the sun but not at 40 degrees? What? Is it a torus of moist air?
That makes no sense, so there must be another explanation.
One thing I should point out in the video that I did not simulate: you can see that the bow is visible in front of spectators very nearby, which means the moisture-laden air is not distant and high-in-the-sky; the videographer is in the air mass.
Looking around the webernets, I see that it is not uncommon afterall.
Googling full circle rainbow, I can find pics of "normal" full circle double rainbows, but also full circle inverted-only rainbows (characterized by having the blue band outside, and red inside).
http://i.dailymail.co.uk/i/pix/2007/08_01/rainbowG0608_468x479.jpg
So I think this is more closely-related to halos or ice-bows, which are due to ice crystals, rather than water-droplets.
Also, they occur at 22 degrees, not at 40 or 50 degrees.
I don't have a complete explanation for the different phenom yet, but I think we're getting closer.
How many crystals/droplets/whatever you think there are between the camera and the monk in the picture below?
This looks like a effect created by the cameras optics, or something attached to the camera.
I know. It's a mystery.
Possibly. I've seen a lot of camera optics effects, but not like this. Not saying I disagree, just that it's a mystery to me.[/QUOTE]
Related to Is a Rainbow Close to the Ground Possible? A Camera Optics Mystery
1. What causes rainbows to form?
Rainbows are formed when sunlight is refracted, or bent, as it passes through water droplets in the atmosphere. The light is also dispersed, or separated, into its component colors, creating the familiar spectrum of red, orange, yellow, green, blue, and violet.
2. Can rainbows be seen at night?
No, rainbows can only be seen during the daytime when the sun is shining and the water droplets in the atmosphere are present. The angle of the sun's rays and the position of the observer also play a role in the visibility of rainbows.
3. Can you touch a rainbow?
No, rainbows are purely optical illusions and do not have a physical form that can be touched. They appear to be at a specific distance from the observer, but in reality, they are caused by the refraction and reflection of light.
4. Why do rainbows sometimes appear as full circles?
In certain circumstances, such as when viewed from an airplane or when water droplets are in the air around the observer, rainbows can appear as full circles. This is due to the refraction and reflection of light at different angles, creating a complete ring of light.
5. Are double rainbows rare?
Double rainbows are not as common as single rainbows, but they are not necessarily rare. They occur when light is reflected twice within the water droplets, creating a secondary rainbow above the primary one. The colors of the secondary rainbow are reversed compared to the primary rainbow.
  • Nuclear Engineering
  • Other Physics Topics
11K
  • General Discussion
  • Classical Physics
  • Feedback and Announcements
  • Astronomy and Astrophysics
  • Beyond the Standard Models
