Possible Way to Measure Dark Energy?
The discussion revolves around the possibility of measuring dark energy and the feasibility of harnessing it through a proposed experimental setup involving a long cord with weights and a generator. Participants explore theoretical implications, challenges, and alternative methods related to dark energy measurement.
  • One participant suggests using a long cord with weights and a generator to measure dark energy, proposing that dark energy could create a pulling force between the weights.
  • Another participant points out that dark energy is incredibly weak and would require a much stronger force to produce noticeable effects in the proposed apparatus.
  • A participant questions whether the cord would need to be many light years long to measure dark energy, considering gravitational interference as a potential issue.
  • It is mentioned that measuring dark energy might require distances on the scale of megaparsecs, and that mechanical binding of the cord could hinder the experiment.
  • Participants discuss the use of laser interferometry as a method for measuring dark energy, noting that no existing technology can operate on such large scales.
  • One participant introduces the concept of measuring redshift drift as an alternative method, although they acknowledge that this effect is extremely small and has not yet been measured.
  • It is noted that findings from redshift drift measurements would not provide new information beyond what supernova observations already offer.
Participants express differing views on the feasibility of the proposed experimental setup and the challenges associated with measuring dark energy. There is no consensus on the practicality of the initial idea or the effectiveness of alternative methods discussed.
Participants highlight limitations related to the strength of dark energy, the scale required for measurements, and the potential interference from gravitational forces. The discussion remains open-ended regarding the viability of the proposed methods.
Orthokid
Hello everyone. I'm pretty new here, and I kinda joined this forum just to post this question. I have read many books on physics and cosmology, and although I have no scholastic training in it currently, I plan to study physics in college. Anyway, I get all sorts of ideas in my head, but this one I am about to share with you has been on my mind the longest. I would really appreciate anyone's input.
Could you not measure dark energy and possibly harness it by putting a long cord with two large weights on either end and a generator with monitoring equipment in the middle? Dark energy would pull the space in between the weight apart, creating a force. The weights would carry the force, and the generator would harness the pulling force. The monitoring equipment would detect ripples and the strength of forces inside/on the cord, providing data that could be used to discern the nature of dark energy. This is certainly not very easy to do and requires a lot of resources, but it could be done.
PS: I originally wrote this question as a comment on a Youtube video, but I realized its not the best place to ask these sorts of questions
Space news on Phys.org
Hi Orthokid, welcome to PF!
The trouble with dark energy is that, in the scheme of things, it's incredibly weak - we can only really notice it on cosmological scales (as an aside: the fact it's so weak, but nonzero is a pretty big issue in physics). For any noticeable effects on an apparatus like the one you described, dark energy would have to be much much much much much much stronger than what it is.
Thanks, I learned something there.
So the cord would have to be many light years long to measure any actual dark energy, or would gravitational interference just completely ruin any possible experiment of this kind? But I guess something similar is happening the laser-based gravity wave detector that is going to be launched, but that's its purpose.
Edit: Sorry, I rant a lot
Try many megaparsecs (millions of parsecs) -- we're talking much more than the distance between galaxies here, we're talking the distance between galaxy clusters -- and even then, the mechanical binding of the cord would probably kill it. You'd need to use laser interferometry, yes, but there exists no such laser or mirror that works on those kinds of scales! Even then, you wouldn't learn anything that supernova observations already tell us.
Yes gravity is vastly stronger over distances less than many millions of light years - which explains why we don't see galaxies flying apart.
And watch the interference pattern change with time. An alternative is to watch the redshift of galaxies change with time, which is called "redshift drift". Of course, this effect is extremely small, and has yet to be measured. Over the years, there has been a number of papers published on the theoretical aspects and experimental possibilities of this.
Measuring redshift drift and using the results together with other date like supernova observations would be very exciting, and could, for example, be used as a test of the Copernican Principle that we are not in special position in the universe.
  • · Replies 0 ·
  • · Replies 22 ·
  • · Replies 31 ·
  • · Replies 30 ·
