Understanding Potential Difference in Simple Circuits
  • Thread starter xyx
You got it. The electrons, on average, move slower in the second example. Therefore, they lose less energy in bulb 01. correction on line 12: I meant "and bulb 01 in example 02(8v)".In summary, the conversation discusses the difference in voltage and energy loss between a single bulb in a simple circuit and two bulbs in series. In example 01, the potential energy drops by 12v over the bulb with a resistance of 2 ohms. In example 02, with two bulbs in series, the potential energy drops by 8v over the first bulb with a resistance of 2 ohms and 4v over the second bulb with a resistance of 1 oh
xyx
Hi,
Sorry to bring this up again but I've been looking so long for an answer to a new question that arrised.
This is how I see it and tried to explain it, so please correct me if I'm wrong.
example 01: 1 bulb in a simple circuit : 12v ,
bulb 01 : 2ohm
expln: potential energy drops by 12 v over bulb; Ok np so far.
example 02: 2 bulbs in series: 12v ,
bulb 01 : 2 ohm , 8v
bulb 02 : 1 ohm , 4v
But here's my problem: THE DIFFERENCE IN V. (POTENTIAL DROP) OVER BULB 01 IN EXAMPLE 01(12v.) AND BULB 02 IN EXAMPLE 02(8V).
Which one is the right explanation?
EXPLAINATION 01:
The energy needed per electron to pass through bulb's 01 ions is still the same so each electron loses the same energy per coulomb but there are less passing so the drop in energy is less over bulb 01.
Since there are less q/s(I)(more energy to spend per electron) every electron starts with more energy (more then with just one light bulb)so it also can get past bulb 02.
But this is a bit in contradiction (to my textbook) with the fact that the potential drop is said to be 8v per coulomb on bulb 01, so the [del]E/q, the drop per electron(loss in energy to go through bulb 01), in bulb 01 is in my above explanation still 12v but since there are less electron the v-meter measures less namely 8v.
EXPLAINATION 02:
The energy needed to pass through light bulb 01 IS less then in example 01 because I is smaller and therefore there is less energy loss in the same bulb(bulb 01) for some sort of atomic reason I don't get(maybe because the electrons are moving less fast)?
EXPLAINATION 01:
I think there is no 'energy needed to pass through'.
Imagine you operate a bulb at very low voltage, so that it does not glow.
You will find that there is a current. In fact, the bulb is a good conductor when it's cold.
Yes, the current is small then. But not because electrons don't have the 'energy needed to pass thru'. The current is small because the electrons move very slowly. Remember, current=charge/time.
I think this is false. Voltage is energy/charge. So, in example 02 each electron does in fact deposit less energy in bulb 01, than it does in example 01. If you so will, it 'saves' some energy for bulb 02. Yes, there are less passing but this has nothing to do with how the 12V distribute over both bulbs.
No. In both examles, each electron starts with exactly the same energy.
The potential drop is just 8V = 8joule/coulomb. If your textbook uses the unit 'volt per coulomb', then it is wrong.
No. The voltmeter measures volts. Which is basically energy per electron. The initial energy per electron is a sole property of the source, no matter what circuitry you connect. (If it's an ideal source, which is the case here).
EXPLAINATION 02:
There is no 'energy needed'. There only is 'energy deposited' per electron. And that's in fact less in example 02 than in example 01.
You're getting closer. The electron deposits less energy in bulb 01 because it moves slower. (And I is smaller also because of this).
The 'atomic reason' is, if you so will, collisions between electrons and atoms. If the electron is slower, it loses less energy in a collision.
Yes.
What is potential difference?
Potential difference, also known as voltage, is the difference in electrical potential energy between two points in a circuit. It is measured in volts (V) and is necessary for current to flow through a circuit.
How is potential difference created in a circuit?
Potential difference is created by a source of energy, such as a battery, which provides a potential difference between its positive and negative terminals. This difference in potential energy causes electrons to flow through the circuit, creating a current.
What factors affect the potential difference in a circuit?
The potential difference in a circuit is affected by the voltage of the power source, the resistance of the circuit, and the type of material the circuit is made of. A higher voltage source, lower resistance, and conductive materials will result in a higher potential difference.
How is potential difference measured?
Potential difference is measured using a voltmeter, which is connected in parallel to the component or circuit being measured. The voltmeter measures the difference in potential energy between two points in the circuit.
Why is understanding potential difference important in simple circuits?
Understanding potential difference is important in simple circuits because it helps us understand how electricity flows through a circuit and how different components affect the flow of electricity. It also allows us to calculate the amount of current flowing through a circuit using Ohm's Law (V=IR).
  • Electrical Engineering
10K
13K
  • Electromagnetism
