‡brandon
- 8
Hi another annoying question from me. I found this walkthrough on how to make potassium chlorate while reading through some things.
http://img92.imageshack.us/img92/999/adsfpj5.png
Think this way will work? It seems like it should work when you think about it, but that's not really what I am asking for. How long do you think it will take to do this? Or how would you know its done? Theres also the crystalization method using bleach and potassium chloride. But I wasnt sure on it too much. Incase you don't know what it is ill post at the bottom. It seems that method using electrolsys should work. Is the way using bleach better, or worse? Does anyone have any other suggestions? I am curious to know just to experiment with. And:
And sorry for all the questions :p
Im just curious.
Take one gallon of bleach, place it in the container, and begin heating it. While this solution heats, weigh out 63 grams of potassium chloride and add this to the bleach being heated. Constantly check the solution being heated with the hydrometer, and boil until you get a reading of 1.3. If using a battery hydrometer, boil until you read a FULL charge.
Take the solution and allow it to cool in a refrigerator until it is between room temperature and 0 degrees Celcius. Filter out the crystals that have formed and save them. Boil this solution again and cool as before. Filter and save the crystals.
Take the crystals that have been saved, and mix them with distilled water in the following proportions: 56 grams per 100 milliliters distilled water. Heat this solution until it boils and allow to cool. Filter the solution and save the crystals that form upon cooling. This process of purification is called "fractional crystalization". These crystals should be relatively pure potassium chlorate.
Im just curious.
