Potential and Kinetic Energy Problem
The discussion revolves around calculating the gravitational potential energy (PE) and kinetic energy (KE) of a softball thrown straight up. The PE at the highest point is calculated to be 59.584 J, but there is confusion about determining KE without knowing the velocity. Participants suggest using conservation of energy principles, noting that KE equals PE at the moment of release and when the ball returns to the thrower. Kinematic equations are also mentioned as a method to find velocity using distance and acceleration due to gravity. Ultimately, the key takeaway is that KE and PE are interconnected through energy conservation, allowing for calculations based on known values.
CeceBear
You throw a softball (of mass 400g) straight up into the air. It reaches a maximum altitude of 15.2m and then returns to you.
What is the gravitational potential energy of the softball at its highest position? Assume the ball departed from and returned to ground level.
Assume no energy is lost by the softball while it is in the air.
What is the kinetic energy of the softball as soon as it leaves your hand?
What is the kinetic energy of the softball when it returns to your hand?
What is the speed of the ball?
PE = mgh
KE = (1/2)mv^2
I've already calculated the PE to be 59.584 J. I'm not sure how to calculate KE without a velocity.
You can try using the conservation of energy principle. Or use the kinematic motion equations. Have you tried either method?
But I only have distance. I don't have time, acceleration, or velocity for the kinematic equations. And according to the conservation of energy law, wouldn't KE just be -PE?
I think you are forgetting one more equation
total energy: KE+PE
so you can try setting up like this using conservation of energy
Initial Total Energy=Final Total Energy
as for kinematic equations, you do have acceleration. You can figure out velocity by finding time it takes to reach the top or fall to the ground using kinematics
funny I just had a question about Conservation of energy as well >_>...starting a new thread..
KE would equal to PE (not -PE) but this depends on when you are talking about. (it would be true if use KE when PE=0 and PE when KE=0)
Ok, I think I've got it now. Thank you very much!
Using the known distance, gravity, and the fact that its velocity is zero at its highest point you can find its final velocity
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
