Potential difference and battery
A battery functions as a "chemical pump," utilizing chemical energy to create a potential difference by separating charges internally, which generates an electromotive force (EMF). The maximum current a battery can support is determined by its pumping rate. In contrast, a capacitor can be visualized as an empty tank that the battery fills with charge. For a deeper understanding of electrical circuits and capacitance, exploring basic electronics books is recommended. This foundational knowledge enhances comprehension of how batteries and capacitors interact in electrical systems.
kartikwat
How does a battery creates a potential difference and what is the intuative way to look at potential difference when studying capacitance
Kartikwat, you seem to be asking a lot about electrical circuits. May I recommend a book on basic electronics? You can find plenty of them at a local bookstore or online.
Yes sure it will be helpful
Just to be clear, I'm not suggesting any particular book, I'm suggesting that you go out and purchase one for yourself if you haven't already. A search for books on basic electronics or electronic circuits should turn up plenty.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
