Potential Energy of a Spring Contradiction?
The discussion centers on the potential energy of springs in two different orientations: horizontal and vertical. Both scenarios involve two identical springs with a spring constant of 5000 N/cm and a 2 kg box compressed 2 cm. The law of conservation of energy indicates that the speeds of the box upon release from the springs, denoted as y and z, should be the same in both scenarios. However, the user expresses confusion regarding the forces acting on the box, particularly in how the horizontal components cancel out in the first scenario, potentially affecting the box's speed.
  • Understanding of potential energy and kinetic energy concepts
  • Familiarity with Hooke's Law and spring constants
  • Knowledge of the law of conservation of energy
  • Basic principles of forces and motion in physics
  • Review Hooke's Law and its application in spring mechanics
  • Study the principles of energy conservation in mechanical systems
  • Explore the effects of force components on motion in different orientations
  • Investigate the relationship between spring compression and potential energy
Students and educators in physics, engineers working with mechanical systems, and anyone interested in understanding the dynamics of spring mechanics and energy conservation.
dtseng96
Hi everyone, I'm a bit confused about the concept of the potential energy. Let's say we have the following scenarios here: https://dl.dropbox.com/u/29312856/Springs.jpg
In the first scenario, we have two identical springs with spring constant 5000 N/cm angled at 20 degrees below the horizontal, and a box of 2 kg is compressed against the two springs, causing each spring to be compressed 2 cm. The entire system is in space, with no sources of gravity nearby. If we release the box from the spring, the box have a speed of y m/s.
In the second scenario, we have the same two springs as before, except placed vertically upwards. The box is compressed against the two springs, causing each spring to be compressed 2 cm. The entire system is in space, with no sources of gravity nearby. If we release the box from the spring, the box have a speed of z m/s.
Using the law of conservation of energy, it seems like the speed y and the speed z in the two scenarios are the same (meaning that it does not matter which way you position the two springs) because the potential energy of the two springs in each scenario are the same.
Yet, it seems illogical that it would be that way. In the first scenario, the horizontal components of the force from the springs would cancel out, so only the vertical components of the force from the springs would propel the box forward. In the second scenario, the force from the two springs are completely vertical, so they do not cancel each other out. It seems like the box would have a higher speed in the second scenario because there is more force propelling the box forward in the second scenario.
Can anyone explain my confusion? Any help would be appreciated. Thanks!
In the second scenario, you need more energy for compression, as 2cm height corresponds to 2cm of compression (this is different in the first setup).
Thanks for the reply, mfb! That makes sense, I did not think of that. I realized I made a mistake in my question though, so I just changed my question a bit right now.
  • · Replies 51 ·
  • · Replies 24 ·
  • · Replies 45 ·
