Potential Energy of a spring problem
The discussion centers on a physics problem involving a spring compressed by 10 cm and a 1 kg mass released onto a rough surface with a friction coefficient of 0.500. The potential energy of the spring is calculated using the formula U = kx², leading to an initial kinetic energy for the mass. The frictional force is determined to be 4.9 N, which will do work on the mass as it moves across the rough surface. The key question is whether the mass will rebound off a wall and return to the spring, and if so, how much it will compress the spring upon return. The solution requires considering the effects of friction on the mass's motion after it leaves the spring.
LalaLapras
A spring with a spring constant of 2000 N/m is compressed 10.0 cm on a horizontal surface. Then a 1.00 kg object is attached to it and released. At the relaxed-length position of the spring, the mass leaves the spring and the table goes from very smooth to rough, with a coefficient of friction of 0.500. There is a wall 50.0 cm away from the release point. a) Determine whether the mass will make it back to the spring after one bounce off the wall, assuming it rebounds elastically with no speed loss off the wall. b) If it does make it to the spring, how far does it compress it? If it doesn't make it to the spring, where is its final location.
U=kx^2 (potential energy for the spring, k being the spring constant)
Ff=uFn
KE= 1/2mv^2
I first wrote down all the givens:
k=2000 n/m
Δx=-.1 m
m= 1.00 kg
Then, I wanted to find Ff
Ff=uFn
I needed to find Fn, so I knew that Fn=Fg
Fg= ma
Fg=(1.00 kg)(9.80)
Fg=Fn= 9.80 N
so i plugged that back into Ff
Ff=(.500)(9.80)
Ff=4.9 N
Then, I used the equ. Kei+Uei=Kef+Uef
Kei is zero, and I think Uef is zero, too, so Kef=Uei.
so,
1/2mvf^2=1/2kx^2
then, plugging in my values, I was hoping to solve for velocity. I got V=4.47 m/s
...but I don't know what to do after that. Any help would be super appreciated!
You can't use conservation of energy in a problem with friction. Your first step is to find the potential energy of the spring which gives the kinetic energy of the mass just as it reaches the rough part of the table. Now friction will do work on the object, what will that do?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
