Why Is the Derivative of Potential Energy Considered Force?
The derivative of potential energy, represented as F = -dU/dx, gives the force acting on a particle, not power. Potential energy can take various forms, such as gravitational or spring potential energy, and the specific function U(x) is less important than understanding that the derivative indicates force at a position x. The negative sign in the equation is a convention that reflects the physical reality that forces act to move particles toward lower potential energy. This convention ensures that the force opposes increases in potential energy, guiding particles down potential "hills." Understanding these concepts clarifies the relationship between potential energy, force, and motion.
transgalactic
the potential energy of a body which mass is "m"
and which is moving in one demention is given by:
U(x)=U0 * (a/x + x/a -2)
what is the power which being put on the body
the solution says F=-dU/dx=U0(-1/a + a/x^2)
which means that they are doing a derivative to the original expression.
but i can't understand why the derivative of potential energy is its power.
from high school i know the potential energy is U=m*g*h
and the only derivative that i know is for a(t)=v'(t) v(t)=x'(t)
so their solution is not logic to me at all
U(x) is a scalar function for potential. F=-dU/dx gives the force on the particle, not the power.
Look at the units of your quantities. A force applied over some distance is the "work" done on the particle; this has units of joules. Now, the work done over some time period is the power; P = dW/dt, which has units of joules per seconds. So, yes, something does seem quite strange if that is what your text is telling you.
Potential energy comes in many different forms. U=mgh is the gravitational potential energy for an object some height above Earth's surface. Another example is U=(1/2)kx^2, which is the potential energy of a mass-spring system. Your function U(x) is just some general function for a potential energy; for this problem, it appears that it is not overly important for you to know what type of potential energy it is, but rather, that by taking the derivative with respect to x, you can determine the force on the mass m at any position x where the potential is defined.
ok i understand that the force which is applied on
is the derivative of U(x)
but the definition of a derivative is dU/dx
why are they writing F=-dU/dx (why they add minus)
The minus sign is just a convention.
Consider a particle of mass m confined within the potential U(x) = x^2. The force on the particle is given by F=-dU/dx, right? Thus, F = -2x. Suppose that the particle is located at x=a with no initial kinetic energy. What is the force on the particle and its direction? F=-2a and the force acts to push the particle to the left, and down the "hill" (parabola). If there were no minus sign in front of dU/dx, then the force would act to push the particle to the right and into regions of higher potential. The minus sign convention seems to offer a better description in regards to physical reality.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
