bfusco
- 126
- 1
An insulating sphere of radius R , centered at point A, has uniform chagre density ρ. A spherical cavity of radius R / 2 , centered at point C, is then cut out and left empty, see Fig.
(a) Find magnitude and direction of the electric field at points A and B.
(b) Find the potential at points A and B. Set V(r → ∞) = 0.
(c) Write down an algebraic solution (no integrals!) for E(r) and V (r) for the space outside the larger sphere, r > R. Choose r = 0 at point A, and the radius vector of point C as r = RC .
(question1) in the uploaded file
(a)First I want to figure out the volume charge distribution, which I wanted to do by finding the the volume of the whole sphere minus the volume of the cavity.
\int_V \rho \cdot dVolume = \frac{4}{3}\pi \rho (R^3-\frac{R^3}{8})=\frac{7}{6}\pi R^3 \rho
Then to get E_B I wanted to use Gauss' law, but I am not sure how i would set that up because the E field isn't isotropic, so instead I am trying to use the equation for E-field of a volume charge distribution:
E(r)=k\int \frac{dq \hat{s}}{s^2}
Where i just calculated dq. s^2=R, but I am not sure what \hat{s} is
