Power and voltage are the same thing?
  • Thread starter Thread starter lastfsdfsd23
    Power Voltage
The discussion revolves around the relationship between power and voltage in electrical systems. Participants explore definitions, analogies, and misconceptions related to these concepts, as well as the role of current in the context of electrical power.
  • Some participants state that power is defined as the product of voltage and current (P=V*I).
  • One participant compares electrical concepts to mechanics, explaining that voltage is analogous to force and power is related to work done over time.
  • Another participant uses a waterfall analogy to describe voltage as potential difference and current as the amount of water flowing.
  • There is a discussion about the misconception that ground acts as a sink for currents, with some participants arguing that ground merely completes the circuit back to the source.
  • One participant mentions that grounding systems can vary, with some being designed to limit fault current to prevent damage.
Participants express varying views on the nature of grounding and its function in electrical systems. Some agree on the basic definitions of power, voltage, and current, while misconceptions about grounding lead to differing interpretations.
There are unresolved assumptions regarding the definitions of grounding and its implications in different electrical systems. The discussion reflects a range of understandings and analogies that may not align with formal definitions.
lastfsdfsd23
I am a student of Electrical . but I am not clear about power and voltage. Is any rapport between them ? I read about this two things . but i can't solve it. Is anyone tell me easily about this topic?
Power is voltage times current. P=V*I.
it's a law
lastfsdfsd23 said:
it's a law
Yes. Before going for electrical power, you should understand the terms voltage and current.
Voltage is the difference in electric potentials of two points in a circuit which drives a current through the circuit. Power is the product of voltage and current.
yeah. that's it. i understand.
thanks for your time.
@lastfsdfsd23
It's just like mechanics. Go back to freshman physics..
Force tries to move something, but no work is done until that something moves.
Work done is Force X Distance moved.
Power is work done per unit time, ie Force X distance/time = Force X Velocity .
Volts try to move electric charge. No charge moved = no work done.
Work done is Volts X amount of charge moved .
Power is work done per unit time, ie Volts X amount of charge moved per unit time = Volts X Amps.
That should get you started.
I remember this one quite easy to remember explanation of the voltage, current and power:
Imagine a waterfall a tall waterfall. The height of the waterfall is the voltage in electrical system called potential difference. Higher the waterfall faster the water will fall down so to speak. Then the amount of water which passes the waterfall is the current. And the "work" let's call it power is in the actual falling of the water on that waterfall.
The work shows up as warming of the water, erosion of the rocks, noise, and any other energy pathway you can think of.
A BTU being 550 er i mean 778 foot-pounds , and Niagara Falls being 167 feet high
you should find the water flowing away at bottom of Niagara warmer than upstream by about 167/778 = 0.21 degreesF .
Do not confuse gravity with coulomb force on charges in a field.
Else you'll think 'electricity' is attracted to 'ground'
which is a widely believed mistake.
[QUOTE="j
which is a widely believed mistake.[/QUOTE]
i thought ground was at zero potential n acts like sink for currents in case of Earth faults...like current would flow into the ground...
That's a common misconception.
Ground only completes the circuit back to the source.
It's not at all a "sink" like Earth is for rain .
"Ground" is best thought of as just another wire that goes most everywhere.. If your source is not connected to "ground" no current will flow into a "ground fault" .Most systems that we encounter are connected solidly to "ground" so that a ground fault will trip the overcurrent device thereby announcing its presence.
There exist in industrial settings systems that are "grounded" by a high resistance so that a "ground fault" will cause only small current to flow. Limiting fault current does two things for you:
1. Limits energy input to the fault. You don't want a high current arc inside an expensive machine. It's easier to repair the damage from a small arc of just a few amps than than that from a multi-kiloamp explosion.
2. Allows a machine to keep running until you can start a backup or arrange to shut it down without upsetting the rest of your plant.
I recommend you read "IEEE Green Book" . It will firmly implant the basics of "grounding" .
  • · Replies 38 ·
  • · Replies 32 ·
  • · Replies 36 ·
10K
