- #36
jbriggs444
- 12,504
- 7,243
I and R are inversely proportional if you hold V constant. Which means that this inverse proportionality, by itself, gives you exactly zero information on what happens if V is allowed to vary.John3509 said:But if I and R are inversely proportional does that still means V and I are proportional?
V and I are directly proportional if you hold R constant. Which means that this direct proportionality, by itself, gives you exactly zero information on what happens if R is allowed to vary.
In the case at hand, R is not held constant while you vary V. It varies, for one thing, because you will use different step down transformers if you choose to run your transmission lines at 20,000 volts versus at 40,000 volts.
