Power of set of choice functions
The discussion revolves around determining the power of the set of all choice functions for P(N) - {0}. Participants explore the relationship between the cardinality of subsets of natural numbers and choice functions, noting that P(N) has an uncountable number of subsets. The conversation highlights the need to construct a choice function f that maps from P(B) to N, where B is a proper subset of N. There is confusion regarding the cardinality of these functions, with some asserting that the number of functions is aleph zero. Ultimately, the participants aim to clarify the construction and properties of these choice functions in relation to set theory.
ben21
Find the power of set of all choice functions for P(N) - {0}.
I really don't know how to start with that. Hope you will give some clues.
Try to look at P(N)=2^n
How many numbers are in N-{0}?
There are \aleph (aleph zero) numbers in N-{0}...
So 2^\aleph equals \Im (continuum)... So it proves, that the power of P(N) equals \Im.. However, how to combine it with a choice function?
Ok so you said P(N) has N amount of number except zero. Now what do you say for this?f(N)=??
by "P(N) has N amount of number except zero" are you meaning, that P(N) has \aleph one-element subsets excpet zero?
f(N)? Do you mean one-element subsets by N as argument?
No i mean that P(N) has an uncountable amount of subsets besides zero.
You have to construct a choice function f and whose range is N-{0}, such that f(N) is an element of N.
OK, but.. amount of subset of P(N) is more than natural numbers.. it is continuum, not aleph zero...
edit::: wrong... I'm a little bit confused.. We need to find a amount of functions f: P(B) -> n, where B is a proper subset of N and n in B...
So I think we are able to construct aleph zero these functions.. P(N) contains as subset the set of N so..
We can build this function like this:
F: P(N) -> N;
F(N) = {case 1 - the power of N equals aleph zero: G(N);
{case 2 - in other case (the power of N is less than aleph zer): max(N)
where G: P(N) -> N.
G(B) -> n, where P(N) containn B, and b in B. We can build aleph zero g functions, because we use it only if the argument of f functions has aleph zero power, so B als has alpeh zero functions - so the set of values of function G has also alpeh zero elements.
It is correct?
