Calculating Iron (Fe) PPM from mL Lab Sample
  • Thread starter Thread starter Puchinita5
    Iron
To calculate the iron concentration in parts per million (ppm) from a lab sample, the initial standard solution of 0.04 mg/mL equates to 40 ppm. When 10 mL of this standard is diluted to a total volume of 100 mL, the concentration decreases to 4 ppm. The conversion involves recognizing that dilution affects the final concentration, so the formula used must account for the total volume. Thus, for each mL of the original standard, the corresponding ppm can be calculated based on the dilution factor. The final concentration in the diluted solution is confirmed to be 4 ppm.
Puchinita5
Hi. I just did a lab where we are to determine the amount of iron present in a vitamin based on its absorbance (after reacting it with hydroquinon and o-phenanthroline) and I am having trouble making a conversion.
At the beginning of lab, we prepared a " .04 mg/mL = 40 ppm " standard Fe solution.
For our calibration curve, we made 1 sample using 10 mL of standard Fe mixed with some citrate (to adjust ph i think), 2mL of hydroquinone, and 3 mL of o-phenanthroline and then diluted with water to 100mL.
Then, samples was made using 5, 2, 1 and 0 standard iron.
I took absorbances and now need to construct my calibration curve, but I am to use concentration, not mL.
Let's say, for the 10mL standard Fe sample. Am I supposed to just say that for every mL, there are .04 mg of iron and for every .04 mg of iron it is 40 ppm. So 10 mL is .04*10=.4mg of iron and .4 mg of iron is 400 ppm ?
is this the correct way to convert?
So I would have
1mL std Fe --> 40 ppm
2mL std Fe --> 80 ppm
5mL std Fe --> 200 ppm
10mL std Fe --> 400 ppm
Is this right? I'm not sure if I need to account for the fact that it was diluted? I'm confused.Thank you!
ppm (parts per million) is a unit of concentration. For water, 1 g = 1 mL, so one part per million is equal to one millionth of a gram per mL (i.e. 1 µg/mL = 0.001 mg/mL).
Your standard solution has a concentration of 0.04 mg/mL = 40 ppm. You then dilute 10mL of the 40 ppm solution into 100mL total solution. What concentration is this 100mL solution?
ok, so for the 10mL standard, would it be 4 ppm since it is diluted in 100mL? 10mL * .04mg/mL *(1/100mL)= .004 mg/mL = 4 micro g /mL = 4 ppm ?
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
