Precision and accuracy of a solution
The discussion focuses on calculating the precision and accuracy of a diluted solution, specifically S=0.4±0.01 in a 250ml volume. Participants explore the formula F=5*S/100 to determine the resulting concentration after dilution, arriving at a value of 8*10^-5±2*10^-6. They emphasize that the relative uncertainty remains constant, but additional uncertainty may arise from inaccuracies in measuring 5ml and 100ml volumes. It is concluded that the uncertainty for all diluted solutions is approximately ±1/40, acknowledging that measurement errors can affect precision. The conversation highlights the importance of considering volumetric glassware tolerances in calculations.
cham
so let's say that we have a solution S=0.4±0.01/250ml
i want to do a dilution
so i pick 5ml and pour it into 100ml beaker
how should i calculate precision of the solution (mathematically or with some other equations)?
so basically we have F=5*S/100
for me 5*S/100=8*10^-5±2*10^-6
is this true because it doesn't seem right for me (about the pricision)?
The relative uncertainty stays the same, that is right.
You might get an additional uncertainty if the 5ml or the 100ml are not exact.
Likes cham
so
so what you say is that no mater how many dilution we do the precision stays the same and it depends on the solution we're using.so it means ±0.01 for all diluted solutions we made,right?
The relative uncertainty stays the same.
It is always 1/40. Roughly speaking, your solution might be 1/40 more concentrated than you thought, or 1/40 less. And that uncertainty does not change if your dilution factors afterwards are known exactly.
Likes cham
so let's assume that final result is true , so it would be 8*10^-5 ±1/40 and so for all resulting solutions
and that by using Δy/y
correct me if I'm wrong
thanks and sorry for my stubbornness
I am afraid you can be sure neither 5 mL nor 100 mL are exact and they are additional sources of error.
Likes cham
No, in this case it would be 8*10-5 +- 2*10-6 as the uncertainty is 1/40 of the value.
With the caveat that the 5ml and 100ml won't be exact, as mentioned.
Likes cham
thank you mfb and Borek for your help
much appreciated
You can use @cham to tag users in the thread.
Likes cham
