Predicting the pKa of a molecule
  • Thread starter Thread starter mycotheology
    Molecule
The discussion centers on estimating the pKa values of certain carboxylic acids, particularly 2-phenylpropanoic acid and flurbiprofen. The presence of a methyl group on the alpha carbon is noted to decrease acidity due to its electron-donating properties. The carbonyl group is not conjugated with the aromatic rings, limiting its effect on acidity. For 2-phenylpropanoic acid, an estimated pKa of around 4.2 is suggested, influenced by the electron delocalization from the phenyl group. The discussion also highlights that flurbiprofen, with its additional benzene ring, may have a pKa around 4.0, as the second ring further delocalizes electrons. The comparison with known compounds like acetic and propionic acids provides context for these estimations.
mycotheology
Heres the question:
http://img266.imageshack.us/img266/5071/sar2.png
I have no idea how to answer either of these questions. I know that the methyl group attached to the carboxyl groups alpha carbon will decrease the acidity due to electron donating properties. It doesn't look like the carbonyl group is conjugated with the aromatic rings so I don't think they will increase the acidity too much. Thats all I can say about it though, I have no idea how to estimate the pKa.
I'm also confused about question b. I suppose one advantage is that the salt is not acidic.
Chemistry news on Phys.org
Start by comparing the acidic group with other known compounds. Acetic acid, pKa = 4.75; propionic acid, pKa = 4.87; 2-phenylpropionic acid, pKa = ?
For b, you are partly correct but there is something else you need to consider. Simple carboxylic acids are fairly polar but this structure has a fairly large, greasy biphenyl group attached.
My guess for 2-phenylpropanoic acid is pKa = 4.2 since the phenyl group is close enough to significantly delocalise the acids electrons. If I'm not mistaken, the F group should increase electron density of the benzene ring because halogens are stronger resonance electron donors than inductive electron acceptors therefore is should raise the pKa a bit. However the second benzene ring in flurbiprofen will delocalise electrons even further so I'm guessing flurbiprofen has a pKa of around 4.0.
It seems like a simple enough question: what is the solubility of epsom salt in water at 20°C? A graph or table showing how it varies with temperature would be a bonus. But upon searching the internet I have been unable to determine this with confidence. Wikipedia gives the value of 113g/100ml. But other sources disagree and I can't find a definitive source for the information. I even asked chatgpt but it couldn't be sure either. I thought, naively, that this would be easy to look up without...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
